SC10 Thread
#1458
Are we looking at the new bodies or the wheels that you can barely tell what they are. FORGET WHAT I SAID ABOUT THE WHEELS seen those at Pegasus hobbies a few weeks back.
BuggyKing thanks for the technical explanation of my stud mod
#1462
KidAgain,
I saw those at the Jconcept race at OCRC. Here is my current setup to if your still interested.
Front:
AE 4 hole Pistons
37.5 Weight Oil
150k limiting ( 5 Limiters)
Kyosho Light Green Springs
Middle hole on tower
Inside on arms
Rear:
AE 4 hole Pistons
30 weight Oil
60k limiting (2 limiters)
Kyosho Dark Blue Springs
Inside on arms
Added 2 Degree of Anti-Squat. Seemed to help with forward bite.
No weight added
Losi XXXT 1 Degree Rear Hubs
AKA foams front and rear
Front:
AE 4 hole Pistons
37.5 Weight Oil
Inside on arms
Rear:
AE 4 hole Pistons
30 weight Oil
Inside on arms
No weight added
#1463
When you say the tabs, do you mean the bits where the strap pivots??? There's bits that stick down at the hinge section that would prevent the battery moving backwards, defeating the purpose of having the movable foam. Correct??
#1465
there are 2 tabs in the back near the pivot point, i grinded mine down during the build. i havent used any weight in mine since i put the battery as far back as it could go
