Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
#1861
I don't have the car yet so I don't have a need for them yet. Thanks though
#1863
In stock!
http://www.rpphobby.com/category_s/4...earch=%2023001
Not to sidetrack the thread too much but, CHECK THIS OUT!!! DEX gets a big sister! http://www.team-durango.com/blog/?p=1672
My order came in today! Thanks again for the help and professional service. I will be putting in another order for some gear fluid soon, and some of those schweet Durango shirts! Keep up the good work.
#1865
Konich, No thank YOU! Glad to hear everything got there ok!
Dangerwr--Yeah...that gear is not likely to come off. lol maybe if you could fit a puller of some type in there?? I hammered mine on too. I didn't want to grind the gears due to the possibility of making the hex too big.
Luckily, Durango has complete Diffs! http://www.rpphobby.com/product_p/tdr210001.htm
#1866
Geez! Now how do you install the outer wheel nut on the front CVDs??? That thing is not going on!!! Nothing on Oople either. Seems likes their crush spacer is too big or not crushing--either one. I cannot get that pin to fit in the groove on the nut. Durango has made some of these parts fit a little too tight and is taking the fun out of this build.
I want to take this thing and race tomorrow but not at this rate. I already had to turn down a part on a lathe! What else?!?
#1870
Registered User
im looking to get a durango wondering if i should get the 410 or the 410r? cant decide if its worth the money for the hopups that come on the 410. if i do get the 410r what are the nessasary hopups if any?
thanks
thanks
#1871
Just get the 410R and the front aluminum suspension blocks and you'll be set. don't forget the suspension balls that have to be used with the aluminum blocks. Some people have changed out the ball cups/ends to standard ones. The Durango ball cups are a little soft and can pop off easy. I used the AE TC5 ball ends and some losi white ball cups on mine. It's way cheaper to start with the 410R since most people like the added chassis flex from the plastic chassis side and rear braces anyway.
#1873
anybody running these batteries in this car?
http://www.hobbycity.com/hobbycity/s...idproduct=9967
They are 31mm, I dont know where the batteries are located in this car but I read somewhere they have 25mm straps. Can I rig something up to make these packs work?
#1874
#1875
ok thanks. You guys know of any other good deals on saddle packs?
