Like Tree22Likes
Old 02-05-2012, 03:50 PM
  #9361
Jpm1's Avatar
Originally Posted by DBL15
anyone got a quick link to download the manual as i seem to have left it in a safe place , that i have no idea where that safe place is
V3 was awesome on a larger outdoor track on the weekend as well i love this buggy
Why don't you just get cookies tonight when you bring the 408 over for her finishing touches, get the girls in the office to photo copy it?
Jpm1 is offline
Old 02-05-2012, 03:52 PM
  #9362
ozzy-crawl's Avatar
Trader Rating: 14 (100%+)
better yet get a android and put the pdf on your phone
ozzy-crawl is offline
Old 02-05-2012, 06:25 PM
  #9363
DBL15's Avatar
yeh i can do that too i guess
DBL15 is offline
Old 02-05-2012, 08:47 PM
  #9364
Trader Rating: 21 (100%+)
Default What motor should I get?
Hey guys im new to this buggy thing so i need some help choosing a motor. Im currently getting a few offers to trade my 13.5T motor and some of my options are Orion VST Pro 5.5T (is this way too much?), Orion 6.5T (black can), or a Losi 6.5T...? Should I just wait it out and get a 7.5 or 8.5?
Ill be using a LRP SXX V2 w/cap.
Id appreciate any info or feedback. So let me know what you guys think and know.
OGKRacing is offline
Old 02-06-2012, 07:01 AM
  #9365
photobrat's Avatar
Trader Rating: 33 (100%+)
Hey guys, question about the center spur assembly. I was going through my car the other day and realized that when I spin the center spur, installed in the car, but with no motor or drive shafts in it, there is a fair amount of friction when I try to spin it. I removed the bearings and pulled the shims from behind them, still a fair amount of friction. I'd think this should spin freely with a good flick but it turns maybe an 1/8 to 1/4 rotation before it stops. Is this normal, or is there a bind in there somewhere? Thanks!
photobrat is offline
Old 02-06-2012, 07:07 AM
  #9366
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
No it's not normal. Try loosening the center mounts, then retighting them with the center assembly in. Repeat until it spins free.
Bman's 3XNT is offline
Old 02-06-2012, 07:10 AM
  #9367
onekiwi's Avatar
depends on what you are going to run. You can always turn down the faster motors on the radio but if there is a 13.5 class I think you will have to run a 13.5
onekiwi is offline
Old 02-06-2012, 07:16 AM
  #9368
photobrat's Avatar
Thanks B, didn't think so...
Old 02-06-2012, 08:29 AM
  #9369
it also helps to loosen the cross brace screw if its to tight it will pinch the bearings.
cm.stites is offline
Old 02-06-2012, 09:58 AM
  #9370
I had a similar issue, but was able to fix it easily. Is it difficult to put the mid drive clamp (wire loop that connects spur cover) in? It should slide in and out fairly easily, and lock in when fully seated. If it takes a lot of force it is compressing down on top of the bearings too hard, causing binding of the mount.
My fix was to sand down the inside of the spur cover that touches the bearings. I had some extra squares of plastic that seemed left over from the mold process. I removed those and sanded down the cover some more and the center assembly spun much smoother. I also noticed that the mid mid drive clamp was MUCH easier to remove and install.
HeatSink5 is offline
Old 02-06-2012, 10:24 AM
  #9371
Mini8 Menace's Avatar
Default hey guys tell me if i have the right set up
I've been doing a lot of research and talking to some guys at the track and they said to start out with a 8.5 turn and tune it down and boost it when i get more comfortable and I'm probably going with a revtech or epic d3 i know there the same manufacture and I've decided to go with the rs pro I'm still trying to figure out what servo would work be i run spektrum electronics but i don't want to have glitch problems and i don't want have to use caps.. or a glitch buster so what would be a good choice and if I'm picking a good setup to start out with
Mini8 Menace is offline
Old 02-06-2012, 10:44 AM
  #9372
dirtydan's Avatar
Trader Rating: 47 (100%+)
What adaptor are needed to use this car on the integy setup station?
dirtydan is offline
Old 02-06-2012, 12:01 PM
  #9373
type c adapters. for the hpi blitz etc.
Old 02-06-2012, 02:00 PM
  #9374
dirtydan's Avatar
awsome thanks for the help.
dirtydan is offline
Old 02-06-2012, 03:52 PM
  #9375
Hey Kiwi, thanks for the help.
