Like Tree22Likes
Old 11-12-2010, 08:27 AM
  #3361
grapejuice's Avatar
Trader Rating: 153 (100%+)
Originally Posted by 1day
The HPI P5 rings are supposed to be better also. Mine just came in and I will give them a try and let you guys know. $1 a pack-can't beat that.
What's the part number?
grapejuice is offline
Old 11-12-2010, 08:29 AM
  #3362
I will post it tonight when I get home.
1day is offline
Old 11-12-2010, 08:34 AM
  #3363
Originally Posted by grapejuice
Negative, got mine from another source , but I did try ordering them through the shop, we'll see if they show up today. Getting parts from Kyosho is the biggest pain in the ass sometimes. I still have a few left..had two packs of them but a gave some to David, Danger and Sam....
how many run are you getting before the p5 ring begin to leak? thanks in advance.
cbrociuos is offline
Old 11-12-2010, 08:37 AM
  #3364
grapejuice's Avatar
Not sure...they haven't leaked yet. Think I have three or four race nights on them now...
Old 11-12-2010, 08:41 AM
  #3365
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
A020.
Are the P-5 rings the same size as the Durango rings? I can't find them in stock, so I'm checking out Mcmaster-Carr for alternatives. Anybody have the measurements on P-5 o-rings (Kyosho or Durango)?
They have a material called "Buna-N," which is supposed to offer superior oil resistance, they also have o-rings with a durometer rating of 70 (might be softer).
t0p_sh0tta is offline
Old 11-12-2010, 11:20 AM
  #3366
INFERN0's Avatar
I just got one of these. I bought the 410r and upgraded only a couple things like front hub carriers, servo mount and added the graphite rear brace to replace the stock plastic.
I am sure there are tons of set ups in this thread but I want to know a great start point with a Tekin 6.5 I assume probably near 23 pinion to stock spur. I set mine up with Associated 30wt front and rear with stock springs , 7000 front and 2000 rear diff fluid on medium grip clay. Any ideas or better set ups any of you trying?
INFERN0 is offline
Old 11-12-2010, 12:13 PM
  #3367
ABBOTT's Avatar
Did you upgrade the front arm mounts? That is a must have. Also dont even bother trying to run a 23 tooth with any brand 6.5 replace it with something smaller (20 tooth) or you will overheat very quickly. Enjoy
ABBOTT is offline
Old 11-12-2010, 03:26 PM
  #3368
INFERN0's Avatar
I was basing the 23 tooth pinion on Randy Pikes suggestion to my buddy with the same car. He was running a 20 or 21 tooth but was told he is undergeared and that's why he is overheating and thermalling.
His car isn't making it past 3 minutes and he thermals out.
The front braces make a lot of sense so I will get those.
I have installed a fan behind the esc beside the spur gear (fan shroud is trimmed away to fit under spur) and the air is drawn over the esc towards the back. I am thinking with the limited space under the body and how tight things are this should creat air flow and eliminate some heat issues when weather gets warmer.
Is anyone else having major overheating issues or is there something to look for to stop it from happening that is build related?
INFERN0 is offline
Old 11-12-2010, 03:33 PM
  #3369
Dlewis4's Avatar
Trader Rating: 148 (100%+)
If you build the car correctly with the proper shimming you wont have heating issues. I have never seen my motor get over 140. Just make sure you have the vents cut out.
Dlewis4 is offline
Old 11-12-2010, 03:34 PM
  #3370
make sure you have a little vent on the side of the body that directs airflow to the esc.
that will help.
also make sure your entire drive chain is smooth.. especially since the car is diff-geared.
LiL_JaSoN is offline
Old 11-12-2010, 04:06 PM
  #3371
INFERN0's Avatar
We run hotter motors like 6.5 here but the motor is not whats getting hot or I would agree with geared to high. The esc is overheating.
I may have it licked on mine but he cant fit a fan as I have.
INFERN0 is offline
Old 11-12-2010, 04:53 PM
  #3372
Konich's Avatar
Whats the verdict on rear sway bars?
I need a little more rear grip, I'm running the lightest sway bar, should I ditch it?
Konich is offline
Old 11-12-2010, 05:49 PM
  #3373
R-E-A-P-E-R-'s Avatar
Inferno is that an RS or a RS Pro
R-E-A-P-E-R- is offline
Old 11-12-2010, 06:06 PM
  #3374
ditch the sway bar. run lighter springs than what came on the kit. im running grey. black associated springs worked pretty well too. i just got the light green in the mail, but havent tried them yet. i have my shocks layed down. inside on tower and outside on arm. my turnbuckle is inside lowest hole on the tower, and outside on the rear hub. im using offset jconcepts ball cups on the rear hubs to maintain droop. im running just shy of full droop. the wheels are almost touching the offset ballcup when car is lifted off the ground. hope this helps. oh ya 1.5* rear hubs, MAKE SURE YOU MOUNT THEM L & R WHEN VIEWED FROM THE FRONT OF THE CAR OR THEY WILL BE 1.5* TOED OUT. try this and you will have all the rear grip you need. i actually run less "hooked up" tires on the rear. i like to ride the slide w/ a 4wd.
Old 11-12-2010, 07:03 PM
  #3375
Team Tekin
Randy_Pike's Avatar
Guys I'd like to see your esc settings if you're thermalling the RS Pro.
I've been running a 6.5 in mine all day long and not getting that hot.
Randy_Pike is offline
