Tekno Conversions Thread
#3046
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
Hi there guys i have a tekno hot bodies kit here ready to start the build of my buggy, Im going to be running two hitec 7955 servos, one for steering and one for the brakes, I will be using the clutch bell system with a 17t clutch bell running max life ally shoes in reverse with mugen 0.8 springs, I have the castle 2200kv motor and matching esc ready to go...
I just purchased 3 x Intellect Lipo Battery (#IP-HW4S5400SP) which is 14.8 - 4s - 5400 - 35c hard case packs that are roar approved to run in the buggy they fit nicely in the battery tray and was wondering what kind of run times i will get with this set up ???
Also what diff oils would suit the brushless set up too ???
I run the hot bodies d8 & d8t in nitro versions so the rest of the set up im sure i will be ok with and already have plenty of spares thats for sure and i plan to set up a tekno d8t verion down the track.......
#3047
I'm using a 4S 5100mah with a 1900 motor geared 48/17 and getting a good solid 18 minutes (15 minute Main and a few practice laps) and put put about 3000 mah. This is geared a little slow at around 32mph (51kph) for indoor tracks.
#3048
I have now been running my local track with the rc8 tekno kit. I love the manual brakes, i have one suggestion though, the motor mount needs to be more like the standard mounts it is very restricted to adjustments and I run to different motor set ups (a novak and a mamba)and it is kind of expensive to have to by another motor mount. Does anybody know if a more like the mount on the other conversions will work with this kit. I love the quality and set up of the kit other wise.
#3049
Well thanks for the reply im guessing that i should be able to get 15 minutes out of the set up using the 220kv instead of the 1900kv you are using and if the punch control is set right get close to 18- 20 minutes out of this packs
What colour springs are you running in the d8, i also have the extended rear shocks and tower to match
#3050
#3051
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
#3052
My shock towers are Tekno front and rear.
My buggy weighs in at 3.85Kg (8.5lb)
#3053
Thanks for the responses guys, i plan on racing 8 minute heats and then 2 x 15 minute finals with my set up i will post pics once the project is finished.
I also plan on running some of the lightened series of products from hot bodies is there any thing i should stay clear of in the brushless
#3054
I just received my Jammin X2e body for my Tekno MBX6 and cut it up. The fit of that body on the Mugen is awesome. It's about a 95% fit. It fits much better than the 8E Slipstream body (~80-85% fit) that I have now. I highly recommend the X2e body for the MBX6. My only gripe about it is that it's not as thick as the proline body, but other than that it's awesome. Get yours from ImpaktRC, it's cheaper than Nitrohouse.
#3055
Got a Tekno kit coming for my OTHER MBX6 buggy ![Big Grin](https://www.rctech.net/forum/classic_images/smilies/biggrin.gif)
Going to try a Proline XB808 body on it.
I would be very interested in seeing some pictures of your X2e body once its painted and mounted if you have any ?
#3056
http://gallery.neobuggy.net/2010-Rac...94398886_dz4Lc
http://gallery.neobuggy.net/2010-Rac...94399951_F2Zys
http://gallery.neobuggy.net/2010-Rac...94399492_DyL3n
Let me know how the xb808 body works for you.
#3057
So are they all X2e bodys in those pics ? I love the Bobby Tillman one. That looks sweet.
#3058
Do I really to run a reverse Y harness with my DX3S or is a normal y harness enough?
#3059
If you hook everything up and the servo is moving in the proper direction, than your good to go. Just adjust everything as needed.
If the servo is moving in the opposite direction that it needs to be moving in, than you would require a "Y" harness with reverse, to make the servo direction change.
#3060
Hi
how warm is your clutch after 15 mins in a truggy?
