Tekno Conversions Thread
#3062
Hi, i have a mbx5r and i see tekno RC don't make conversion kit for that car.
do you think the mbx6 conversion kit can be use to convert my mbx5r?
#3065
If I'm gonna use a Hitec 7955 on my Tekno conversion, one way would be to use a Reverse Y Harness. If not, can I buy a Hitec HFP-20 programmer to change the rotation of the servo so I won't need to use the harness?
#3066
On my MBX-6, I set up my linkage to push to apply brakes instead of pulling... No reverse programmer or reverse y-harness needed. Just a standard harness works fine. I'm not sure what buggy this will be used on but it might be worth checking if you can make it work this way.
#3068
You could get a programmer to reverse rotation. But like unsp0ken said, you may not need either. Some cars can push OR pull the brakes. Mugen, Jammin, Associated (if you file the stops on the diff plate) can all push or pull, so you don't need anything except a simple Y harness. Just make sure you aren't engaging the brakes on throttle and you should be good to go. Losi, HB, and Kyosho only work one way and may require a reversing Y harness.
#3069
How about an esc mount that makes it so you no longer need to use fans, can seal up your car tight, and takes all the blows that your wrecks and big hits can deliver?
#3070
#3071
If your not using clutch springs then why wouldn't you just use a hard pinon w/ mechanical brakes?
#3073
Theres nothing that a little neutral throtle can't fix.
#3074
