Tamiya mini cooper
Doesn't matter how big the track is. Mini doesn't get boring.
in australia mini always runs the same track size as the other cars. i cant see why we'd want to run a smaller one?
Our track out here in Dayton Ohio has a 120ft straight, needless to say the straight is long enough,...the twisty bits inside are fun to.
CVA shocks and short springs
Got an M03 that was already fitted with the oil filled cva shocks but kit springs. Ran it for the first time sunday and if i put anything but kit tyres on the front it rolled so got some short springs. Now ive fitted them i have no suspension travel at all and the shock bodies are on the spring platforms! Is it ok to run on a carpet track like this or should i space them?
If the spacers are missing you can buy them seperately (#50598).
Mini's feel better on a small track than a TC, but I don't think that means they should have a small track!
In my view the absolute minimum for a 10th track is 8mx16m, 12mx24m and upwards is better. This is based on 2m lanes and the possibility of a variety of corners.
Quick question....I hate the chatter that the stock axles make on my m05. I was thinking about getting the spec-R (double jointed)cvd's, however they are kind of pricey. Are the less expensive (single jointed) cv's good enough, or should I spend the extra dough on the spec-R's?
The Yeah Racing ones look more promising !!!!!!
Those yeah racing ones are even more expensive than the specR ones. They look very similar in design though. Looks like I'm just going to pony up and get the specR's.
I've had good luck with the 3 Racing V3 axles. They're single jointed, but work quite well.
Anyone use a locked front diff at all?
Use a Yeah Racing ecs or SpecR ecs, and no more wear, no chatter !!!!! Single joint , even if you don't hear any chatter, drives don't work, you need an ecs drive(double joints).........
