Tamiya mini cooper >
Tamiya mini cooper
Like Tree288Likes
Tamiya mini cooper
Old 03-04-2015, 01:39 PM
  #22996
sakadachi's Avatar
Originally Posted by DesJardins
If you're ordering from progressiveRC you can add the deans charge lead & the balance board you'll need.
I purchased the combo with case so it came with the balance Board for JST connectors & I just added the nice Deans charge lead
In that pic you will also see the balance board extension for the 4S lipo. But if your charging out of the vehicle you won't need any extensions
Ahhh, thanks for the information! Yes, I do plan on ordering from ProgressiveRC since you guys recommend them.
Correct, I will be charging out of my car because I will be running multiple packs. I plan to get 2 rounded housing ones for my M05 to start.
Then if you guys can recommend me what Lipo to get for the M-Four
sakadachi is offline
Old 03-04-2015, 02:37 PM
  #22997
Heathen's Avatar
Originally Posted by fig865
Hey Mini Cooper racers! If you're on facebook, a group was started for any Tamiya M-Chassis discussions or pictures to be shared. Feel free to check it out and join.
https://www.facebook.com/groups/RCMiniCooper/
No need for this group, lots of good m-chassis groups on Facebook. M-chassis united it a good one.
Heathen is offline
Old 03-04-2015, 02:40 PM
  #22998
fig865's Avatar
Trader Rating: 43 (100%+)
Sorry bout that. I only searched for mini cooper groups and found none. The new group will be deleted. Thanks.
fig865 is offline
Old 03-04-2015, 11:47 PM
  #22999
Rcnutguy's Avatar
Originally Posted by avink007
Chassis, hinge pins, 3x6mm set screws for setting droop on the arms, motor mount, 1.5mm spacers for the motor screws, and arms.
Many thanks
Rcnutguy is offline
Old 03-05-2015, 10:41 AM
  #23000
sakadachi's Avatar
Hi guys! I have a quick question regarding my M05 setup. While entering a corner under decent traction, the rear of the car tends to want to step out especially turning right. Not as severe going left.
What do you guys recommend for this type of behavior as far as setup/weight?
I am currently using yellow short springs on front, red springs in the back, #800 Tamiya damper oil using the factory CVA super mini single hole piston (it is not that stiff). I don't want the rear of the car stepping out like this.
Thanks.
Actually, until I can fix this issue I will not be getting Lipo's for the car because it will only make the car go faster and make the situation worse.
I have no such issue on my V2.
Old 03-05-2015, 11:02 AM
  #23001
eR1c's Avatar
I noticed that my rear end tended to slide out a bit w/ the Tamiya racing slicks on asphalt (S-Grips and front and rear anti-sway bar seemed to solve this for me). Also if I take corners too hard, ...I kind of have to roll through corners, letting off on the throttle slightly, then picking it up again towards the end of the corner.
eR1c is offline
Old 03-05-2015, 11:52 AM
  #23002
sakadachi's Avatar
Thanks eR1c. I am running the D60 radial S-Grips on all 4 corners. I tried remedying this by using stiff inserts in the front and soft in the rear. Did not help much. I have rear camber setup at the same angle as my V2 and it helped significantly, but still not perfect.
I am using full tread traction compound on the rear, and only one stripe down the middle tread on the front tire. This helped the most, but the wear on the rear tires' outside 10-15mm vs V2 shows that the rear tires are getting overwhelmed and car not setup correctly.
Going left through the corner is good, but going right through the same corner, the rear steps out.
I might try the swaybars. My M03 runs swaybars but that was more gimmicky than really helping to stabilize the car.
Old 03-05-2015, 12:10 PM
  #23003
Neils74's Avatar
So after spending a day switching over to the M-05 V.II Chassis. I have hit several stumbling blocks.
I can only hope it's my rushed build and setup and that I am missing something glaringly obvious, but my front uprights Tamiya (54177) hit the righthand side of the chassis at about 80% lock. It's fine if I want to turn left, I just have to hope there are not too many right turns in the near future.
Secondly, do not bother switching to the titanium screws. stripped three heads already, and now they are stuck. Hopeless rubbish.
The front suspension arm set has a screw hole on both arms which also give very little ground clearance and will have to be cut off... nothing is ever simple.
And lastly, my nimh packs are too small for the V.II chassis.......arrrggghh.
Attached Thumbnails Tamiya mini cooper-mini1-v2.jpeg   Tamiya mini cooper-mini2-v2.jpeg   Tamiya mini cooper-mini3-v2.jpeg
Neils74 is offline
Old 03-05-2015, 12:35 PM
  #23004
howardcano's Avatar
Trader Rating: 37 (100%+)
That sounds like a corner weight (tweak, to RC guys) problem. Adjust the shock collars (and sway bars, if connected) to put a little less weight on the left rear tire, and a little more on the right.
The M05 isn't static balanced too well from side to side, so a tweak board may not get the handling symmetrical. Make the final corner weight adjustment on the track.
howardcano is offline
Old 03-05-2015, 01:45 PM
  #23005
sakadachi's Avatar
Thank you, howardcano. I will raise the rear left just a tad and see how it goes.
The funny is my V2 is slightly the other way around (rear wants to slightly step out while turning left) but not as severe as my M05. Will dial that out as well.
Old 03-05-2015, 01:52 PM
  #23006
sakadachi's Avatar
1) I only use the factory uprights (same as the M05's) on my V2 and no issue on the full steering lock clearance. Might want to try your M05's.
2) You can try a tool called Easy-Out. Most hardware stores have them. It's basically a coarse reverse drill bit that bites into your screw head while you drive it out with your power tool. I work on real cars as a hobby too, so I have such tools handy.
3) I noticed that too on my V2. Is that for the swaybar set? I was thinking about just cutting that off at the bottom of the arms since it's just a nuisance.
Old 03-05-2015, 01:58 PM
  #23007
sakadachi's Avatar
eR1c- btw, which Dynamite charger do you use?
Old 03-05-2015, 05:55 PM
  #23008
eR1c's Avatar
They do work, but they ain't "easy"! (I spent about 4 hrs removing a broken head stud from my engine years ago w/ an easy out). -lot's of swearing!!! It should be a lot easier w/ an RC vehicle!
If you have the space what you can also do is use a dremel and slice a "line" into the top of the screw, thus making it a slotted screw. Then use a slotted/flat head screw driver and get the screw out (just make sure the fit is tight when you go at it w/ your screw driver ..any play will potentially strip the remaining portion of the screw head). I've done this on several occassions. This works if you still have the screw head can can get access to dremel it.
I use this charger:
http://www.dynamiterc.com/Products/D...ProdID=DYN4064
I have used 4 different chargers over the years.. This one I find the easiest to use, has some nice features like a temperature sensor and timer. I kind of wish I bought the dual charging one, -it would come in handy for my races ..when I need to charge multiple batteries between heats.
eR1c is offline
Old 03-05-2015, 06:29 PM
  #23009
sakadachi's Avatar
Looks good, eR1c! I was looking at the black 200w if going ac/dc.
Good idea about dremeling a slot.
Old 03-05-2015, 06:50 PM
  #23010
R/C Tech Elite Member
monkeyracing's Avatar
Neils, the upright hitting the chassis is a bit of a pain, but you probably don't want full lock anyway. Most racers I know run less than 80%. Full lock leads to tire scrub and chattering axles.
As for that bit hanging below the arm, hack it off. It's there so Tamiya didn't have to make separate L/R pieces.
monkeyracing is offline
