Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree14Likes
Tamiya F104 Pro!
Old 05-02-2012, 03:08 PM
  #8206
Fred Hubbard's Avatar
Originally Posted by MikeR
Will have lots still on friday, not so sure for sat
Yes, bumper braces are finished but just not have had time to market and package them. Maybe late next week.
I'm trying to resist the F1 temptation due to not having time to run it along with my TC program but dood you aren't making it any easier Nice wares man!!
Fred Hubbard is offline
Old 05-02-2012, 04:00 PM
  #8207
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
More eye candy from Exotec
Big surprise
Well done, again Mike
RedBullFiXX is offline
Old 05-02-2012, 09:15 PM
  #8208
lightfoot's Avatar
Default UF1 Series
UF1 race this Saturday ... Japanese Grand Prix...
Raffling off a New Tamiya F104 Pro Version II kit...
For more info:
http://uf1series.com/index.html
lightfoot is offline
Old 05-03-2012, 08:39 AM
  #8209
Dan
Dan's Avatar
Trader Rating: 75 (100%+)
Dan is offline
Old 05-03-2012, 08:40 AM
  #8210
Originally Posted by sidecarphil1
Hi guys
I am looking for some advice , I am running the ETS set up of tyres this is rubber medium Ride tyres all round , but i am struggling for on power understeer , i have got an F104pro with the soft T bar and the screw removed from the middle hole and using a foam from a shock glued to the T bar ,
middle shock is standard red spring and 300 oil
front is stock , and the middle friction plate has blue corally damper syrup on it , did try diff grease but this made it a little worse , any ideas guys ???
Thanks Phil
anyone ???
sidecarphil1 is offline
Old 05-03-2012, 08:48 AM
  #8211
Pro10noob's Avatar
Can't help you there Phil as i run the F104 Pro in wide config and foam.
The ETS ride tires have the problem that the car is pushing when exiting the corner.
Perhaps running a bit more camber up front?
Or slightly harder setup at the rear?
regards Roy
Pro10noob is offline
Old 05-03-2012, 09:09 AM
  #8212
robk's Avatar
Trader Rating: 22 (100%+)
anyone ???
Start leveling the center shock off.
robk is offline
Old 05-03-2012, 10:51 AM
  #8213
Trader Rating: 1 (67%+)
Just in case anyone is interested. Forced to sell.
http://www.rctech.net/forum/r-c-item...-upgrades.html
supertech is offline
Old 05-03-2012, 01:21 PM
  #8214
tudor_47's Avatar
Thumbs up
Originally Posted by Dan
Looks like Tamiya done their homework. Quick release front damper Mount to make battery switch easy. what looks like a Pancar motorpod in the rear. Low profile front damper Mount. I like it.
tudor_47 is offline
Old 05-03-2012, 01:23 PM
  #8215
MikeR's Avatar
Trader Rating: 15 (100%+)
Big surprise
Thanks guys. F1 for the win!
MikeR is offline
Old 05-03-2012, 01:34 PM
  #8216
MikeR's Avatar
anyone ???
There is not a lot you can do to adjust for that on the base F104.
You might try more steering throw. At IIC the Tamiya guys were grinding the stoppers on the front lower arms to get more throw.
Also try;
Firmer rear top spring.
Tighter diff to force the inside wheel to break loose.
Less front droop.
Less front toe out.
More fr camber.
Space the rear wheels wider, front wheels narrower.
If you had the F1R then I would have simply suggested firmer side springs
MikeR is offline
Old 05-03-2012, 02:33 PM
  #8217
I just ordered the X1, looking to find good servo for it.
In PRO I use normal touring car servo and that is too big(too much bump steer)
What would you suggest, savöx 1251 low profile, or futaba 9602 midi servo -mr Jun likes the futaba but is that the "best" option under ~80$ ?
-others? -would like to get 1 that can be installed to reduce bump steer.
fastvee is offline
Old 05-03-2012, 05:03 PM
  #8218
treborwd22's Avatar
Originally Posted by Vector03cobra
F104 X1 for sale
link
http://www.rctech.net/forum/r-c-item...o-battery.html
PM me if interested, pass it on if you would.
Thanks F1 racers.
I sent you a PM last night!! I have been waiting all day to take this off your hands
treborwd22 is offline
Old 05-03-2012, 06:00 PM
  #8219
Looks like with some minor tweaking that would work on the FGX as well
Man sometimes I think your on a 1 man mission to make me go broke! LOL Way too cool man...Will have to order one or two with my next pay check
InspGadgt is offline
Old 05-03-2012, 06:05 PM
  #8220
Yeah...looks like the rear pod from the current 1/12th scale.
