Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 04-30-2012, 01:17 AM
  #8191
texastc's Avatar
Originally Posted by PDR
Grabbed the R-Sector widening kit for my F104 to have a bit of a play. All worked well, except the diff-side axle is a little loose and causes the rear wheel to wobble. In part, this is because the wheel sits on less of the hub part which is anchored to the main axle.
Any suggestions on the best way to stabilise it?
The new kits ship with shims, contact RSector or whomever you ordered from, they should have the shims.
texastc is offline
Old 04-30-2012, 02:38 AM
  #8192
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
Thanks - must have just missed out. What size are they? Might be just as easy to pick some up locally, since the postage might be worth more than the shims...
PDR is offline
Old 04-30-2012, 07:02 AM
  #8193
RedBullFiXX's Avatar
Trader Rating: 34 (100%+)
Ok F104 pros, I need some help. I keep having the lower ball on the front arm pop out. I have changed balls, and even changed lower arms, still pops out. Any ideas? I'm sure its something simple. But Im not catching it.
Try setting your lower A-arm bump stops to limit the movement beyond droop
RedBullFiXX is offline
Old 04-30-2012, 01:56 PM
  #8194
F104 X1 for sale
link
http://www.rctech.net/forum/r-c-item...o-battery.html
PM me if interested, pass it on if you would.
Thanks F1 racers.
Vector03cobra is offline
Old 04-30-2012, 05:49 PM
  #8195
Suspended
Trader Rating: 69 (100%+)
Yes, you have to use the bump stop screw at the arms to prevent the lower ball from popping out, and the thick washer to prevent jamming the steering knuckle to the arm upon impact.
eComet is offline
Old 04-30-2012, 06:33 PM
  #8196
texastc's Avatar
Thanks will try that.
texastc is offline
Old 05-01-2012, 07:02 AM
  #8197
Trader Rating: 37 (100%+)
I just purchased an f104w, I want to change the front end to the alum camber links like everyone else appears to be running, can anyone give me the parts I will need?
Thanks!
mapplegate is offline
Old 05-01-2012, 12:27 PM
  #8198
Hi guys
I am looking for some advice , I am running the ETS set up of tyres this is rubber medium Ride tyres all round , but i am struggling for on power understeer , i have got an F104pro with the soft T bar and the screw removed from the middle hole and using a foam from a shock glued to the T bar ,
middle shock is standard red spring and 300 oil
front is stock , and the middle friction plate has blue corally damper syrup on it , did try diff grease but this made it a little worse , any ideas guys ???
Thanks Phil
sidecarphil1 is offline
Old 05-02-2012, 12:02 AM
  #8199
MikeR's Avatar
Trader Rating: 15 (100%+)
Hi Gang,
Some new F104 goodies!
http://www.exotekracing.com/f1-adjus...-set-for-f104/
MikeR is offline
Old 05-02-2012, 12:28 AM
  #8200
Trader Rating: 21 (100%+)
wow, nice! Are you going to produce the carbon brace that goes from the camber block to the body post too?
silencery is offline
Old 05-02-2012, 01:19 AM
  #8201
texastc's Avatar
Originally Posted by MikeR
MikeR,
I love you,
Dont sell out before Friday!!!! I gotsta have one!
texastc is offline
Old 05-02-2012, 01:26 AM
  #8202
blade072's Avatar
Trader Rating: 98 (100%+)
with upgrades like these coming out.....ill never get to run my car........they are just too darn pretty to be used...
blade072 is offline
Old 05-02-2012, 04:16 AM
  #8203
dfx
dfx's Avatar
foam wheels, pit tires
2mm under 4mm above
no slop
carpet pretty smooth
4mm ish
Aren't there only 5mm of shims (with stock knuckles)? I believe that the orignal plastic shims are (slightly less than) 2.5mm, 1.5mm and 1mm...
dfx is offline
Old 05-02-2012, 04:52 AM
  #8204
blade072's Avatar
you are correct.....thats why i went and got some alloy ones...but any 3mm spacer/shim can be used....i got these ones...
http://www.tamiyausa.com/product/ite...oduct-id=53539
blade072 is offline
Old 05-02-2012, 01:22 PM
  #8205
MikeR's Avatar
MikeR,
I love you,
Will have lots still on friday, not so sure for sat
Yes, bumper braces are finished but just not have had time to market and package them. Maybe late next week.
MikeR is offline
