Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 05-03-2012, 10:27 PM
  #8221
Originally Posted by MikeR
There is not a lot you can do to adjust for that on the base F104.
You might try more steering throw. At IIC the Tamiya guys were grinding the stoppers on the front lower arms to get more throw.
Also try;
Firmer rear top spring.
Tighter diff to force the inside wheel to break loose.
Less front droop.
Less front toe out.
More fr camber.
Space the rear wheels wider, front wheels narrower.
Thanks Mike i wil give these points a try
If you had the F1R then I would have simply suggested firmer side springs
If the rules allowed it i would man , but it says Tamiya only parts and no other makes of chassis and the car is only allowed to a max of 180mm it is the "fun" class at ETS
sidecarphil1 is offline
Old 05-04-2012, 05:33 AM
  #8222
nrtv20's Avatar
Originally Posted by treborwd22
I sent you a PM last night!! I have been waiting all day to take this off your hands
It’s a great car, immaculately cleaned and prepared every race. It was one of if not the quickest car every week where I race.
nrtv20 is offline
Old 05-04-2012, 07:39 AM
  #8223
treborwd22's Avatar
Originally Posted by nrtv20
Itís a great car, immaculately cleaned and prepared every race. It was one of if not the quickest car every week where I race.
You think you could get ahold of him and let him know Im wanting this? Funny Im spending all day thinking about F1 and I dont even have the car yet
treborwd22 is offline
Old 05-04-2012, 09:05 AM
  #8224
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by InspGadgt
Looks like with some minor tweaking that would work on the FGX as well
Man sometimes I think your on a 1 man mission to make me go broke! LOL Way too cool man...Will have to order one or two with my next pay check
Yes and most definitely yes
MikeR is offline
Old 05-04-2012, 12:23 PM
  #8225
spring71's Avatar
Smile
Exotek Adjustable Arm Set For F104 is available at TQ.
http://www.tqrcracing.com/shop/produ....asp?p_id=3408
FYI, Thanks.
spring71 is offline
Old 05-04-2012, 07:37 PM
  #8226
texastc's Avatar
MikeR, what's the purpose of that cf nose piece?
texastc is offline
Old 05-04-2012, 07:45 PM
  #8227
iPearl's Avatar
Trader Rating: 96 (100%+)
Prevents the F60 nose from Flexing xD
Adds some Stability maybe for the buttom piece that it is bolted onto the chassis.
I believe its unreleased piece.
iPearl is offline
Old 05-04-2012, 09:19 PM
  #8228
Prevent flex in the nose. If you hit the front hard enough you will either strip the thread holding the nose to the wing or bend/crack the front of the body. Would I imagine be more useful for bodies with a high nose.
Mike R - Wondering what those tasty looking new front arms weigh? Am trying to understand if there is any additional benefit on top of the adjustability and strength. Would the heavier arms actually help generate more front traction?
Cheers
John
J-PaP is offline
Old 05-06-2012, 02:40 PM
  #8229
On X1, are there any advantages(other then looks,maybe weight) using the motor spacer if alloy motor mount is used?
-Disadvantages?
Also, do you prefer standard bearing in diff or thrust type?
fastvee is offline
Old 05-06-2012, 02:50 PM
  #8230
dfiantii's Avatar
Trader Rating: 18 (100%+)
Only disadvantage to the spacer I can see is if you have a motor that has a short shaft for you to bout your pinion on like the silver can motor. Then you pinion can't mesh with your spur gear. I think most people are doing the thrust bearing over the standard bearing. At least thats what I am doing on my F1R.
dfiantii is offline
Old 05-06-2012, 08:23 PM
  #8231
idbdoug's Avatar
Trader Rating: 41 (100%+)
What are the correct springs for the front end?
Also,looking for "soft" center shock spring!
Having hard time finding correct one's for F104Pro X1. Already ordered incorrect springs once, so I want to get next order correct!
This
Idbdoug
idbdoug is offline
Old 05-08-2012, 06:39 PM
  #8232
k_bojar's Avatar
Trader Rating: 30 (100%+)
for the guys that have the low profile servo in place, anything special to mount it? i vaguely remember seeing guys showing how they were mounted, but I can't remember where I saw it.....
i guess I should have said, mounting it horizontal instead of vertically like in the directions that's what i get for posting 1/2 asleep
k_bojar is offline
Old 05-08-2012, 10:14 PM
  #8233
warnos's Avatar
Default f104wgp
The t bar in the 104wgp having a hard time finding a spare as a backup.. are the 3 racing one piece t bar the same size? the wgp one is made out of frp has onyone broken one?
warnos is offline
Old 05-10-2012, 08:41 AM
  #8234
dfx
dfx's Avatar
Exotek servo mount works well for me and steering links as horizontal as possible - 5-6mm of shims to servosaver...
dfx is offline
Old 05-10-2012, 09:03 AM
  #8235
Pro10noob's Avatar
Quick question for you all knowing guys....
Who has the part number of the complete black shock that is with the F104 PRO black/WGP/X1??
regards Roy
Pro10noob is offline
