Tamiya F104 Pro! >
Tamiya F104 Pro!
Like Tree16Likes
Tamiya F104 Pro!
Old 06-04-2012, 05:25 AM
  #8356
Originally Posted by kb525
Hows the RC F1 scene in finland? Im currently living in the espoo area and will be going this summer to pick my car up from the states.
check your pm
fastvee is offline
Old 06-04-2012, 05:27 AM
  #8357
Originally Posted by Taman
Nice vid fastvee what do you do to waterproof your electrics? Last time I drove in the rain my car stopped after 1min as I got water in the receiver, was fine after I dreid it out.
I just wrapped the esc and rx with plastic(piece from plastic bag and zip tied it tight,. Got balloons to use next.
No problems so far, but if you are using brushless, I dont know how that will work, brushed is not that difficult to use when wet.
-Pate
fastvee is offline
Old 06-05-2012, 10:38 PM
  #8358
kneedeeppow's Avatar
Originally Posted by kneedeeppow
nice work on that video. the lotus looks good in the rain
here is a shot of mine from todays session. postman delivered my exotek front nose piece thingy yesterday so gave it a good run today. it stiffens up the wing nicely.it kills almost all the vibration from the front wing endplates.
here is the video.dam it was cold
http://youtu.be/fk5F2GyhCLQ
kneedeeppow is offline
Old 06-05-2012, 11:42 PM
  #8359
The receiver is fairly easy to seal, but be aware that it can still short over the connectors. Back in the days I used some sort of electronics sealant to cover the entire printboard inside, and vaseline to cover the connectors. Shoegoo or similar (apparently in the UK there's a lighter version called Lazygoo which seems to do the job pretty well) to seal up the edges and cable entrance, vaseline on the shaft. I used an MRT waterproof ESC, but a ESC can be done in much the same way, provided it doesn't get too hot. Never bothered with balloons and such.
Note that this was with brushed mild modifieds, and NiMh packs. Ymmv with current lipo and brushless.
ijdod is offline
Old 06-06-2012, 02:41 AM
  #8360
Taman's Avatar
Trader Rating: 67 (100%+)
thanks guys ref water proofing. I'm using brushless which seemed to be working fine, it was just the receiver that stopped. I'll give it a try next time.
cheers
Taman is offline
Old 06-06-2012, 04:58 AM
  #8361
k_bojar's Avatar
Trader Rating: 30 (100%+)
cheers
a few years ago, at a HPI Challenge in New Jersey, we had a HUGE rain delay - track completely under water...and Andy from HPI has his cyclone with brushless and lipo (and this was infancy of BL) and had ZERO issues...
he just covered the receiver and speedo (with HPI stickers, of course) and he ran on that wet track...it was awesome to watch..
took the car off, let it dry and everything was good
k_bojar is offline
Old 06-06-2012, 05:03 AM
  #8362
cheers
I believe motor only has rusting problems to worry with water. ESC and RX have electrical problems.
kb525 is offline
Old 06-06-2012, 05:11 AM
  #8363
I have used brushless on boats and unsensored(lol) motor did survive many sunken ships, but sensored motors is the thing Im not sure... -if the sensor shorts, maybe that can damage the esc?
I have one brushed f104 with cheap electronics for rain and onboard video and another with quality parts for racing, makes it easy to drive one on wet surfaces when electronic are worth less then 50 usd ..(compared to ~300$ worth of elec.that my X1 has)
fastvee is offline
Old 06-06-2012, 07:59 AM
  #8364
metalracer2's Avatar
Trader Rating: 20 (100%+)
Just got my F104X1 together and wired up. I'm taking it to the track tonight. Lets see how fun these things are to drive.
metalracer2 is offline
Old 06-06-2012, 08:26 AM
  #8365
i have just 1 f104w and use it in mildly wet conditions at times. Yea it has a free to me brushed esc and rx. plus wheels outside body limit how wet it gets
kb525 is offline
Old 06-06-2012, 06:50 PM
  #8366
F N CUDA's Avatar
Trader Rating: 34 (100%+)
Tell us how it goes, and where you ran it.
F N CUDA is offline
Old 06-07-2012, 07:29 AM
  #8367
I went to TQ. Sean helped me get it set up. By the end of the night it was running pretty good. Just need some softer front springs and better tires.
It was pretty fun to drive. Cant wait to get it on the track again.
Old 06-07-2012, 06:46 PM
  #8368
Trader Rating: 43 (100%+)
selling some trg f104 parts
http://www.rctech.net/forum/r-c-item...l#post10833715
aceinthesky is offline
Old 06-07-2012, 06:49 PM
  #8369
idbdoug's Avatar
Trader Rating: 41 (100%+)
Converted my F104ProX1 to wide configuration! For those who want to do this, the parts i used are as follows::
Carbon Reinforced Frt F103 suspension arms:::#54153
3x31mm stainless shaft F103::::#9804420
Frt ball bearings 5 x 8 unflanged-----need 4 of them
F103 frt and rear tires
F103 frt and rear rims
If using stock plastic servo holder parts you will need #9804419 spacer set
Optional Parts:
Either F103 or F104W body set
I bought F103 F1 Turbuckle set #53150 but you use any metric one's of correct length.
You may need to order c clips if you don't have extra's because wide front uses 3 per side up front versus 2 per side for narrow F104.
You don't necessary need F103 or F104W wide body set. I going to use an regular F104 Pro body set that i have lying around but i will eventully get a wide body set.
Hope this helps for those looking to do wide conversion. It's allot cheaper than buying the F104 GP new.
idbdoug
idbdoug is offline
Old 06-07-2012, 08:58 PM
  #8370
F N CUDA's Avatar
Foam or rubber on the rug? (both kick ass there)
F N CUDA is offline
