Tekin RS ESC sensored >
Old 04-12-2011, 06:36 AM
  #20236
Joel Lagace's Avatar
I'm am looking over a car for a friend of mine and i wanted to get clarification on the LED codes.
His ESC has the latest software loaded. I was reading through the manual and came accross the section called RS DRIVE MODES. Reading though here suggested that we should be seeing LED 5,6 and 7 lit up "dimly" verifying a working sensor system..
His does not have those LED lit. When Powered on LED 4 is lit at neutral and as you use the brakes or throttle the LEDS count upwards as throttle is applied.
I do not know what MODE his is set in DUAL DRIVE or SENSORED ONLY but assume the sensor wire is nessary for both. And i should be seing 5,6,7 right?
I will try a new sensor wire to see if these LED's light up. But before i beat my self up over this, can u regular tekin users confirm i should be seing the dimly lit 5,6,7 LEDS? Is it possible these do not apply to the latest firmware? the manuals dont always get updated.
Thanks in advance..
Functionally everything appears fine, the car drives well.
Joel Lagace is offline
Old 04-12-2011, 06:38 AM
  #20237
M-Technic's Avatar
Trader Rating: 15 (100%+)
The LED's still light up dimly as you rotate the rotor.
M-Technic is offline
Old 04-12-2011, 06:42 AM
  #20238
JCarr's Avatar
You will see led's 5,6,7 if you rotate the drivetrain over. You should see them rolling from one led to the next as you rotate the motor over.
JCarr is offline
Old 04-12-2011, 06:53 AM
  #20239
thanks guys, i tried a sensor wire, no joy, looking for a second wire to try.... might be the hal inside the motor then...
So powered on just push the car on the ground to rotate the motor and my LED4 at neutral should go and and 5,6,7 should come on dimly... So far that is not happening. So looks like a sensor wire or motor issue..
Thanks ill report back if i solve this.
Old 04-12-2011, 06:56 AM
  #20240
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
http://go.redirectingat.com/?id=42X1...%23post8848601
20 SMOKE is offline
Old 04-12-2011, 07:05 AM
  #20241
thanks SMOKE those are great..
Looks like its the motor... 3 wires later still not 567 action.
Thanks guys
one last question, it does not matter if the car is dual mode or not correct?
IF a motor swap is not available right now, is there any danger to the ESC if he continues to use this? He runs a 9.5 lrp.
Old 04-12-2011, 07:41 AM
  #20242
20 SMOKE's Avatar
there is no problem in using dual mode,the led's are very dim and can be hard to see if your out doors
20 SMOKE is offline
Old 04-12-2011, 09:53 AM
  #20243
ahpeq_ong's Avatar
guys, any setup for 17.5t zero timing...?
thank you...
ahpeq_ong is offline
Old 04-12-2011, 10:13 AM
  #20244
Buckaroo's Avatar
thank you...
What kind of vehicle? Touring car? 12th? Rock Crawler? 2WD Buggy?
Buckaroo is offline
Old 04-12-2011, 05:00 PM
  #20245
bigodedonato's Avatar
hi
I am new to the forum, and I have one question, anyone know please tell me the maximum degree of turbo rs pro?
I have also the wobbywing strem stock, and I know it goes from 0 ° till 64 °
Tekin but from I have no idea
could someone help me?
thanks
Bigode
a, excuse the English, I'm on google translator because I do not speak no english
bigodedonato is offline
Old 04-12-2011, 05:29 PM
  #20246
20 SMOKE's Avatar
75 in the esc + motor timing
20 SMOKE is offline
Old 04-12-2011, 05:56 PM
  #20247
smilekt's Avatar
what the best end rpm for straight lane at 120 feet? running touring at 10.5t.
smilekt is offline
Old 04-12-2011, 06:14 PM
  #20248
Team Tekin
Randy_Pike's Avatar
15k to 20k
Randy_Pike is offline
Old 04-12-2011, 06:41 PM
  #20249
smilekt's Avatar
Originally Posted by Randy_Pike
15k to 20k
thanks randy pike ..
smilekt is offline
Old 04-12-2011, 09:24 PM
  #20250
mikel33's Avatar
Trader Rating: 2 (75%+)
running 10.5 TC and I seem to be losing rip after a handful of laps. Fast as all get-out at the start but 10 laps in I am running basically a 13.5 w/ no timing. tried it in 'blinky' mode and it is does not seem to have the speed or rip a 10.5 should.
generally 30+ timing and 10 turbo. nothing really extreme. I've swapped motors and batteries. track is 90x40
looking for an idea of what I might need to do. speedo has some miles on it but has never been hot or cross-wired.
gearing is 6 +/- a tooth or two. 5-10 timing on motor.
thanks in advance.
mikel33 is offline
