Tekin RS ESC sensored >
Old 04-10-2011, 06:59 PM
  #20221
wingracer's Avatar
Trader Rating: 24 (100%+)
Originally Posted by tr1kstanc3
I just loaded the Vegas 212 software following the instructions off Tekin's website and now my RS does not have any LEDs come on when I power it on in my car. It will not respond to throttle input. What is going on??
Did you re-calibrate it to your radio.
wingracer is offline
Old 04-10-2011, 07:10 PM
  #20222
tr1kstanc3's Avatar
Trader Rating: 18 (100%+)
Here is what is going on. When everything is plugged into the car the only radio input I have is steering input. When I turn everything on the ESC (RS PRO) does not make a beeping noise and there are no LEDs that come up on the status screen.
When I connect the ESC up to Hotwire there are no status LEDs that come up on the ESC and Hotwire can not get past the initial screen into the dashboard settings.
So in conclusion: steering works, no status LEDs, factory reset does not work, no throttle available.
tr1kstanc3 is offline
Old 04-10-2011, 09:48 PM
  #20223
teeforb's Avatar
Trader Rating: 94 (100%+)
I'll post here as well.
Hey,
what are most of you guys running for 1/10th 4wd mod buggy? sensored or dual mode?
I have a durango 4wd running rs pro and lrp 8.5t.
Also, what's the difference in speed, runtime, or in general between sensored vs dual mode? Let's say all timing (turbo, boost) is zero across the board. How do they both compare?
thx
teeforb is offline
Old 04-11-2011, 12:11 AM
  #20224
smilekt's Avatar
Issue resolved.
can u explain how & why ?
smilekt is offline
Old 04-11-2011, 06:26 AM
  #20225
tr1kstanc3's Avatar
I reloaded the Hotwire software on my PC and re-flashed the software onto the ESC which worked the 2nd time. It resolved the issue on the RS. However, I am still experiencing issues with the RS Pro which I purchased 2nd hand from a user on the forums.
From my previous post:
Old 04-11-2011, 06:30 AM
  #20226
Buckaroo's Avatar
Sounds like the BEC is working, so you know that the box is getting power, but the Tekin brain is dead. If you bought it second hand recently, I'd say a friendly email is in order! Either way, sounds like it's going to have to go in for repair.
Buckaroo is offline
Old 04-11-2011, 03:02 PM
  #20227
wollow86's Avatar
Could someone help me with some starting settings for a boosted 17.5 on road class? This is first time dealing with boost and turbo, so im really not sure how to set it up.
Here is a track map:
http://www.nearmap.com/?ll=-32.92734...h&nmd=20110211
wollow86 is offline
Old 04-11-2011, 04:06 PM
  #20228
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
read over this it is a how to and what the rs does http://www.carsrcracing.co.uk/?p=244
20 SMOKE is offline
Old 04-11-2011, 05:01 PM
  #20229
Trader Rating: 19 (100%+)
how big is the track, could help you easier.
COLD AS ICE is offline
Old 04-11-2011, 05:46 PM
  #20230
wollow86's Avatar
The track is 45m x 32m with a fast first corner onto the main straight which is about 35m long.
wollow86 is offline
Old 04-11-2011, 06:08 PM
  #20231
20 SMOKE's Avatar
40 timing boost
15 turbo
5 motor
3-5 start rpm
11500 end rpm
fdr 5.5
delay .5
ramp 2
check temp 2 min in
20 SMOKE is offline
Old 04-11-2011, 06:15 PM
  #20232
smilekt's Avatar
oh ic so sad.. so ur rs pro i think have internal fault .. need send to repair ..
smilekt is offline
Old 04-11-2011, 06:48 PM
  #20233
speedybill's Avatar
Trader Rating: 73 (100%+)
Wink ally RDX [yeah, that old junk!!]
Sorry for this ?, I know somewhere in the last 13?? pages an answer to my question is there but I'm too darn lazy to look
135x85 asphalt track
mod TC
Corally RDX [yeah old!!]
Tekin RS
10.5 for now
possibly an 8.5 later
spool in the frnt
any setup help would be appreciated
Thankx, Bill
speedybill is offline
Old 04-12-2011, 01:05 AM
  #20234
wollow86's Avatar
Originally Posted by 20 SMOKE
40 timing boost
15 turbo
5 motor
3-5 start rpm
11500 end rpm
fdr 5.5
delay .5
ramp 2
check temp 2 min in
Thanks heaps.
Is this with timing advance set to 100?
wollow86 is offline
Old 04-12-2011, 04:49 AM
  #20235
20 SMOKE's Avatar
Thanks heaps.
always
20 SMOKE is offline
