Tekin RS ESC sensored
Any suggestions for a setup for WGT, 13.5 motor, 1 cell, large asphalt track that gets very hot? Help is much appreciated.
Hi All
I'm looking for a good setup for 13.5 Ballistic motor boosted.
Guys if you're asking for setup help we need a LOT more info:
Track Size:
Motor used:
Gearing:
Current Esc Setup:
Track Size:
Motor used:
Gearing:
Current Esc Setup:
R/C Tech Elite Member
Problems rs in sc 10.5 Started stuttering and if use brakes to a complete stop motor will not go untill you give it a push all the while steering still works?
That's a sensor problem of some sort. Possibly some dirt blocking one of the sensors or the sensor wire isn't working properly.
when i opened the motor and touched the bars one of them felt loose. this intermittent connection combined with the more agressive timing made the motor erratic.
running 10.5 TC and I seem to be losing rip after a handful of laps. Fast as all get-out at the start but 10 laps in I am running basically a 13.5 w/ no timing. tried it in 'blinky' mode and it is does not seem to have the speed or rip a 10.5 should.
generally 30+ timing and 10 turbo. nothing really extreme. I've swapped motors and batteries. track is 90x40
looking for an idea of what I might need to do. speedo has some miles on it but has never been hot or cross-wired.
gearing is 6 +/- a tooth or two. 5-10 timing on motor.
thanks in advance.
thanks in advance.
Use the RS's sensor checker feature to determine what is going wrong. It can be the motor, sensor harness or unlikely but possible the esc.
I've had that problem myself. Check sensor wire, it's always good to have a spare. Clean your motor (sader, dirt, etc.). Make sure u don't have too much timing in your motor, I've had that problem with ballistic motor.
