Tekin RS ESC sensored
Ok the life pack hit 7.4 peak voltage. 8.39 for the lipo and not sure about the voltage the booster puts out. The speedo with the booster I've had since 5the rs came out so I wasn't suprised when that one went it had many hours on it. The other two where only a few months old.
"C1 and C2 are not in use as of yet, but they will be used for user programmable profiles in future software versions.
*Factory Setting is THP3 Linear*"
just curious, most radios offer exponential, wouldn't this combined with the deadband and minimum throttle settings on the esc provide the adjustment you are looking for?
Currently the custom "throttle profiles" are disabled. They're being worked on right now.
Li-fe's in the beginning were never that high voltage wise, they too have been getting "better" in the voltage department.
In the three graphs the first is what we have now. The second could be if boost profiles were added. This could be linear (middle), soft (lower), and aggressive (upper). It would change how fast timing was added once the motor enters the rpm range of the boost. The third graph would be manipulated timing over the entire RPM range starting at zero. Assuming zero motor timing the esc would start the motor out at a certain level of timing and add timing slowly over the lower rpm range. This could benefit on a tight infield keeping the esc from adding too much timing too quickly. The line then steepens as rpm increases in faster sections and levels out at the top range.
I'm not saying this is the way it should be, just another way it could (possibly) maximize performance and efficiency.
very upset with my tekin rs as stated in previous posts with the 12 67 leds flashing.sensor cable motor soldering poor ect.just got new sensor cable and a new speed controller.tried new sensor cable first still 12 67.installed new speed controller old sensor wire and motor and everything works fine.i'd say its probably like 90 percent of time it's the speed control.who can i talk to to see if tekin will cover a 3hr. of use tekin rs.had over 90 days but didn't know they have a self life.
i think people may have misunderstood your question. they are pointing you to the custom 'timing' profiles. but you were asking about custom 'throttle' profiles.
Thank Randy .. we will waiting ....
The sensor cable has NOTHING to do with this fault. Led's 12 67 is a connection error between the esc and the A B C motor wires. It can be a motor, wire, or an esc.
The first step is to grab a known good motor and hook it up to the esc. If it powers up, bad motor. If not, try your motor wires next. If it sill shows 12 67 make 100% sure you're on a brushless motor type(MT 1-3).
Also if this is a 1s application, try a 2s battery to verify your booster/rx pack is providing enough power.
new ..
hy is they any new firmware comming out ??
What would you want it to do?
done with tekin great controller when it worked reminds me too much like a victor iq charger great features but just not reliable.good luck with them.
