Tekin RS ESC sensored >
Old 06-14-2010, 11:48 AM
  #15106
Yes I'm new to electric I'm running the ESC with 13.5 motor at NorCal.
immrwright7 is offline
Old 06-14-2010, 01:16 PM
  #15107
nothing wrong with my brakes
set at 100% on the speedo and 60% on my DX3s
more than that and they lock up !!!
sidecarphil1 is offline
Old 06-14-2010, 01:42 PM
  #15108
Problem that I'm having now is that my car doesn't gain speed going down the backstrech! Is it that my timing boost is too high?
Old 06-14-2010, 02:30 PM
  #15109
Team Pink's Avatar
Trader Rating: 20 (100%+)
Originally Posted by Still Bill
Randy. None of those team drivers typically run 17.5 setups. With so few posts, I have to think that Mr. Wright is probably new to the hobby.
Mr. Wright. What motor do you want a setup for? And what class will you be running? Assuming that you are talking about Tekin setups for the upcoming Asphalt Nats.
Otherwise, we are all waiting for the new 2.08 Tekin software which will require some testing before we have input on new Tekin ESC setups with the different motors.
Bill...A NorCal regular
Here is the 17.5 setup I used on carpet at Norcal and should be a fairly close starting point for outside there.
File Type: pdf
Team Pink is offline
Old 06-14-2010, 02:32 PM
  #15110
Team Pink's Avatar
Then here is a 13.5 setup that I have tried on the asphalt track at norcal and was great.
File Type: pdf
Old 06-14-2010, 04:05 PM
  #15111
vazzo's Avatar
Trader Rating: 101 (100%+)
I have an issue with brakes as well. I'm running the rs pro with a 10.5 duo1 I have set the epa to 140 and then upped it to 150 after calibration, it's set to 100 on the speedy and still no brakes. The radio I'm using is the KO Eurus. Hope someone out there has a cure as I dont particularly want to run a Hobbywing
vazzo is offline
Old 06-14-2010, 04:10 PM
  #15112
xray09ACT's Avatar
Do you use drag brake? I do.
I have no problems.
xray09ACT is offline
Old 06-14-2010, 04:12 PM
  #15113
20 SMOKE's Avatar
Trader Rating: 103 (100%+)
start end rpm
20 SMOKE is offline
Old 06-14-2010, 04:22 PM
  #15114
STLNLST's Avatar
Trader Rating: 32 (100%+)
For the KO radio set throtle epa to 90 then set your speedo then up the epa to 140. For some reason this is what must be done on the KO radio.
STLNLST is offline
Old 06-14-2010, 04:23 PM
  #15115
STLNLST's Avatar
The settings I posted work for 13.5 as well. You can up the end rpm by 2,000 if you're looking for more straight away speed.
STLNLST is offline
Old 06-14-2010, 04:39 PM
  #15116
I remember reading awhile back that the mod guys sometimes have to run 2 capacitors...I was thinking on trying that myself so I was wondering how they are wired, series or parallel?
InspGadgt is offline
Old 06-14-2010, 04:51 PM
  #15117
P.I.M.P's Avatar
Trader Rating: 14 (100%+)
hi guys need some pointers i have a x12 17.5 lrp combo with rs and i ran it at the same settings as all my other motor and it got to 120deg with in 1min of the race with air and track temps about 20deg then took it out and put a v3 speedpassion and temps where 55deg all day.can some one post a setup for a x12 17.5 combo.cheers
P.I.M.P is offline
Old 06-14-2010, 05:15 PM
  #15118
20 SMOKE's Avatar
what is the motor on,it needs to be on the 4dot(-10) or lower the timing boost way down
20 SMOKE is offline
Old 06-14-2010, 05:36 PM
  #15119
P.I.M.P's Avatar
hi it is on 4dot how much timing boost should i take away
P.I.M.P is offline
Old 06-14-2010, 05:44 PM
  #15120
20 SMOKE's Avatar
post your set up
20 SMOKE is offline
