Tekin RS ESC sensored
Randy,
i actually did use max timing and max boost two weeks agoo for a race in Rucphen; http://www.youtube.com/watch?v=DRBQnRHLBLQ
this however is a little nitro movie but does give a indication about the track.
motor became 80 degree C after a 7 min heat, so pretty nice! without this maxed boost and turbo i coudn't get to a proper speed with the LRP 10.5.
i did ofcourse start with a lower value to look at the temps but they never exceeded the 85C... so i think it is possible!
Mark
Mark
What motor are you running ??
I had been using max timing and max boost in my 17.5 tourer but had no additional motor timing and a 3000 start 18000 end rpm. Everyone said it wouldnt work but it was really quick at the end of a very long straight and had awesome rip with a 6.4 fdr. Temps were around 65 to 75c all day. I think the large rpm range kept the heat under control.
i was running my tamiya 416, with a LRP 10.5 x11.
normally at my local track, www.erceracing.nl i run a nemesis 13.5
so i went to the Rucphen track and started with mild timing to find a proper gearing. however this made my motor just 65 degree C, so i tried full timing and full boost and a little lower gearing for one minute, and it stayed a nice temp, then raced longer and also stayed below 80C, so here is my setup. i think i went just as fast as the modified guys, but with less acceleration. i also beated the 1:10 nitro guys on the back straight
i particullary know how the motor feels if it boggs down, i tried a lot of tekin settings on my local track (erce) with my nemesis 13.5 to figure out what boost range would be good. so but the 10.5 did not bog down but also because i like to keep some corner speed at that track.
setup:
FDR: 5.33
Timing on motor: 10 i think, cant clearly see...
boost: max
turbo: max
start: 8K
end: 25K to 30K
delay: 0.4 or 0.5
ramp: 1.0
push: 0
drag: 0
reverse: 0
brake strength: 100
neutral width: 10
BL-FW
profile: 5
software: 203
also, cooling with a 30x30x6mm Fan from muchmore, and Tamiya cooling ribs with cooling paste
hey phil,
setup:
FDR: 5.33
boost: max
turbo: max
start: 8K
end: 25K to 30K
delay: 0.4 or 0.5
ramp: 1.0
push: 0
drag: 0
reverse: 0
brake strength: 100
neutral width: 10
BL-FW
profile: 5
software: 203
setup:
FDR: 5.33
boost: max
turbo: max
start: 8K
end: 25K to 30K
delay: 0.4 or 0.5
ramp: 1.0
push: 0
drag: 0
reverse: 0
brake strength: 100
neutral width: 10
BL-FW
profile: 5
software: 203
i am at Groningen and have been looking at differant set ups people run
Hi guys experiencing a weird problem with my tekin off load if you rev u can hear turbo coming in when car is on the track it feels like it has no bottom end n turbo will not come in, never had an issue with this before only recent... Any ideas could it b the motor? It's a gm 10.5
thanks
thanks
thanks
thanks
GL
Mark
Has anybody ran the Tekin ESC at NorCal Hobbies? Any good setups I can borrow? Thanks in advance.
thanks
thanks
RS temp was the first LED, and motor temp was 155 degrees using a 40mm fan for the full 6 minute run. Air temp was mid 90's, and track temp was around 130 degrees.
A local suggested my end points might need to be adjusted (for WOT/delay recognition). It would be nice to see some other ideas...
by the way, now thinking on my own situation, I recently had simmilar problems! i did have low end power but not have a turbo boosting in. the car just stuttered on the back straight. the strange thing about this is that the first 3 to 4 minutes i dont have any problem. but after that the car does not kick into the turbo and therefore lack top end speed. i replaced my sensorboard wich solved the problem. the only thing i can link to this is that i once had a little short circuit of my spools touching the sensorboards metal parts. however the thing just works, i guess till a certain temperature or so...
when in my last race with this sensorboard it just didn't work anymore. it just looked like my battery was completely empty. a lot of stuttering and no speed at all...
someone got this and know what it is?
Now that's a silly question! Kevin Jelich, Derek Stephansen, Jason Moberly and Clint Riley are all on the team and all race onroad at Norcal. I'm sure anyone of them can help you with a setup.
Randy Heading out to do some testing on this large nitro track
Any suggest for 10.5 novak ss or tekin redline
http://www.youtube.com/watch?v=K1HLXfuvfL4&feature=fvw
Thanks Wayne
Thanks Wayne
Does the hotwire interface work with MAC?
