Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
Yes I agree about supporting the towers, I have a set of spare towers from a touring car that im going to bolt onto the back of the 410 towers hopefully this stiffens them up to take a beating. Incidently what type of track is your standard team setup based on?
Wow, I run on a large 1/10 track with large jumps that easily accommodates 8th scale cars comfortably and my car takes some ridiculous spills and it keeps right on going. This past weekend I was clipped and pushed into a pipe while at full speed (my car is FAST) and the right front arm sheered off completely at the center point but it doesn't mean there's something wrong with the car. Plastic vs speed, weight and G-forces means something WILL break upon instant deceleration. You can't expect a car traveling at these insane speeds to not break if you get it wrong.
Whenever something has broken on my car it's been with good reason.
First of all the oil is based on outside temp. Hotter the weather, the heavier we go. The standard setup is for 25C temps. Adjust your oils step higher or lower accordingly. Tires are the main things we change when on low bite. Normally opting for soft or supersoft AKA impacts, HB megabites, Proline Holeshots, or Proline Blockades. We normally use X2 scrubs in front all season outdoors regardless of grip. The harder front tires and tire pattern keeps the car from pulling too hard out of corners with aggressive steering. So we just adjust the rear tire for grip. Impacts normally have more grip, holeshots tend to be a bit more aggressive in steering. And Blockades when the tracks get rutted.
For indoor med-high bite clay, we use Ions or Typo in Super Soft, and use a 1.3mm front sway (especially when the track is small and tight for more steering) If you like a lot of steering use the same compound front and rear. Super Soft. If you like a more neutral car, you can run soft up front.
Outdoors prefers the 1.5mm sway. If you run on 8th scale type tracks, sometimes the 1.7mm front sway is nice and tames the car down. Again, same compound if you like steering, or one step harder in front or a more neutral car. It just makes it easier for those drivers who don't like so much steering to be able to run the same suspension package. So if I was to test my teammates car, I just throw my tires on that I like and check if any of his settings are off.
http://www.sidsraceway.com/event-pictures/
To prevent roll over, make sure the springs up front are not to soft. If the front end is soft, it will roll under during a turn, and take the rear with it. The new pistons will help a lot as well, using the 2 hole 1.6 and 1.7 pistons to stabilize the front end. It is very hard to roll a car with these pistons as they provide pack, or resistance to sudden jolts. The pistons are easily the best upgrade, especially for the price. Now if they would roll the top of them for a quicker return?
@Dino: I'm currently experimenting with a similar idea of tire compounds. Silver and Gold compound Dirt webs. Gold up front on the 4WD and silver in the rear. I often feel like the car has a bit too much steering up front so this does seem to calm it down a bit. It was a bit hard to tell because the tires took a bit to break in and the rear wasn't totally locked down. I think next time out will be solid. I'll be able to compare next to my ions as well. Best lap times I could get in my last practice session at OCRC were in the 20.5 second range, while I watched hartson run 18.5 second lap times as a reference not that I'm at his level!
The 410 is a little bit nose heavy, hence the steering. On high bite its awesome, on low bite, you need to add more weight in the rear with the brass skid to balance it out. Hence the reason either to use the 21 caster blocks or 1 step harder front tires. Meanwhile the latest trend is going shorties. Would like to see a new chassis similar to the worlds where you can put the short and motor in the rear. It will help make the car lighter and more nimble.
@Dino: I agree. i've been running the rear tresrey 30g under diff weight for quite a while. This along with the 21 castor blocks has really made the car easier to drive.
@Bman! Nice! So is that a longer chassis on both the 3 diff "v5" and the shorty "v5" ??
Thanks!
Yes longer chassis. +10 I believe. It's been a year now since I made the chassis. It's the same chassis except the shorty chassis has a few extra screw holes.
Another bad day at the track I broke the front bulkheads and worse all the online shops are out of stock till early December and I had a major race this month
