Like Tree22Likes
Old 07-29-2014, 04:56 PM
  #16396
rc_dude's Avatar
Trader Rating: 131 (100%+)
Originally Posted by the incubus
The Dremel is your friend!
Words to live by.
Yeaaaaaa, I need to get one of those lol
rc_dude is offline
Old 07-29-2014, 05:57 PM
  #16397
vito's Avatar
how hard is it to add a servo after its it all done with the biuld
vito is offline
Old 07-29-2014, 06:35 PM
  #16398
rcjunky1's Avatar
Pop all the inner front turnbuckles, pull the center slipper assembly out, remove 8 screws and the whole rack assembly comes out, just bolt in your servo and you're good to go, so not too hard when you know what your doing.
rcjunky1 is offline
Old 07-30-2014, 04:06 AM
  #16399
jreeves's Avatar
I prefer to flip the buggy on its back and remove 16 of the 18 screws from the front end of the chassis (leaving the 2 siderail screws). Then the whole front assembly comes off as one unit and I can set up the new servo, plug it in and center it with the radio before re-assembly. Takes about 10 minutes.
jreeves is offline
Old 07-30-2014, 10:10 AM
  #16400
vito's Avatar
lets see if I got this right stock diff oil is 5000 in the front 3000 out back and the shock oil is 40 wt in the front and 30 in the rear for a v4
vito is offline
Old 07-30-2014, 10:23 AM
  #16401
trick25's Avatar
Trader Rating: 28 (100%+)
choose your servo wisely grasshoppa. its a pain to evict one you dont like.
trick25 is offline
Old 07-30-2014, 06:21 PM
  #16402
rc_dude's Avatar
Originally Posted by 13Maschine
I think they should fit over the shock tower a bit more, and also cover the shock nuts. Which I think means they might have to mount from the back or some other way….The shock nuts tend to dig in when the car flips over so it would be nice to have a smoother surface to skid along in the unfortunately and "rare" event of a flip
I say you go the Schumacher rough all the way and screw all else. Those work exquisitely well and aide a tad in aero.
Originally Posted by Bman's 3XNT
Can you print it upside down, then just grind the supports off the bottom(top) of the part after it's finished?
Ok, the main problem I'm facing is if it covers the whole shock nut and mounts on the same screw, how are you going to get them on and off without being able to hold that nut? The shock tower on these doesn't really have another good place to mount them too. The only other thing i see would be to mount them on the bolts holding the tower on and that would require people cutting up there front diff holder.
Would you guys rather cut up the diff holder or just have one like these that allow you to grab the nut with pliers:
rc_dude is offline
Old 07-30-2014, 09:10 PM
  #16403
vito's Avatar
some one have a oil set for the shocks thinking 40 in the front 30 in the rear
vito is offline
Old 07-30-2014, 10:16 PM
  #16404
the incubus's Avatar
Trader Rating: 17 (100%+)
I run 33 up front and 28 rear w the stock pistons.
the incubus is offline
Old 07-30-2014, 10:28 PM
  #16405
Both look good but I think it would be easier if we had a thin open end wrench to slide underneath to make installation and removal easier. Great work!
Old 07-31-2014, 11:02 AM
  #16406
vito's Avatar
is 30 wt in the shock a goo starting point
vito is offline
Old 07-31-2014, 11:32 AM
  #16407
Dino_D's Avatar
I run 42wt front 2x1.6 and 30wt rear 2x1.7 7k front diff , 3k rear diff
Dino_D is offline
Old 08-01-2014, 02:09 PM
  #16408
13Maschine's Avatar
Smile
I'm running 10K front and 7K rear. What do you feel running the thinner weights in your diffs does? slightly less responsive? is this in your B5.2? I'm having trouble keeping track of all your setups and cars!!! :P
13Maschine is offline
Old 08-01-2014, 06:43 PM
  #16409
vito's Avatar
is there a good way to put in the diff case bolts there 1.3 mm odd size?
vito is offline
Old 08-01-2014, 07:51 PM
  #16410
trick25's Avatar
if you have the original allen hex it should be in there.
trick25 is offline
