Like Tree22Likes
Old 12-31-2011, 09:51 AM
  #8896
Trader Rating: 29 (100%+)
Originally Posted by spiro
I've seen several nice hop-ups thoughout the many pages of this thread. As I'm currently waiting for my full line of Durangos to arrive, I'd like to prepare. There are many nice-to-have items, but I'm looking for the gotta-haves. After some time of testing, what would you say are the essentialts of must-have upgrades that I can order even before the build?
The Aluminum rear diff hoop is a must, I broke 2 of the plastic hoops. Also get the Aluminum suspension holders, and both aluminum gear box inserts, upgrade the servo saver crank. I do like the Aluminum caster blocks but they are not a must have.
Walkman is offline
Old 12-31-2011, 10:17 AM
  #8897
1shnot's Avatar
Originally Posted by Chris-s
Hopefully you can see that photo. For the front I trim 3 or 4 rows off the outside, 2 off the inside and then use a dremel to smooth off the bumps left behind from trimming. Then glue round the sidewall and where you have trimmed/sanded the pins off, but only the outside.
For the back I trim and sand one row off the outside only, maybe two depending on what the corners are like.
Are you ruuning small or big bores? As I can post some setups for either.
Awesome thanks!!! I'm running reg shocks not big bores... do you find sways absolute must for extreme high traction?
1shnot is offline
Old 12-31-2011, 02:43 PM
  #8898
jmackani's Avatar
Trader Rating: 14 (100%+)
Good stuff! I've been eyeballing the Tresrey diff-hoops and servo-saver arm. What about the diff leakage problem? Have Durango fixed this, or do I need to get some 3rd party seals?
The v3 has upgraded seals already.
jmackani is offline
Old 12-31-2011, 05:57 PM
  #8899
Rideordieguy1's Avatar
Trader Rating: 45 (100%+)
Cool Gear question...
Just put my V3 together and am running a 6.5 tekin pro with the 87 stock spur. What's a good starting pinion for a tight indoor track. Thanks.
Rideordieguy1 is offline
Old 12-31-2011, 06:04 PM
  #8900
Teambcw's Avatar
Trader Rating: 28 (100%+)
Hey guys selling my 4wd.. have to sell my saddle packs.
http://www.rctech.net/forum/r-c-item...dle-packs.html
Teambcw is offline
Old 12-31-2011, 08:53 PM
  #8901
Originally Posted by Bugle
Yeah, that's cold, I get motors over 80 deg C sometimes without damaging them.
Thanks for that.
Would running the 22 pinion make it run cooler that 20 pinion I am currently running. (stock spur)
dusty sweep is offline
Old 01-01-2012, 11:15 AM
  #8902
spiro's Avatar
Thanks for the tip bud! I'll prolly order these, but skip the caster blocks. I guess I'll have my upgrades before the car...
Come on Durango! Produce!
spiro is offline
Old 01-01-2012, 11:17 AM
  #8903
spiro's Avatar
Perfect! Only red bling "needed" then.
spiro is offline
Old 01-01-2012, 04:58 PM
  #8904
Trader Rating: 25 (100%+)
Still debating viper vs. Tekin. The only reason I'm leaning towards viper is because it comes with a program car but with tekin you have to buy a hotelier which are expensive right?
D-A-N-4-4 is offline
Old 01-01-2012, 05:02 PM
  #8905
jmackani's Avatar
I have the truck and the buggy and have yet to have problems with either of the diff outdrive supports. The only part that everyone appears to be using shrink wrap for is the cvd retainer. The rear one normally snaps on installation.
jmackani is offline
Old 01-01-2012, 05:07 PM
  #8906
jmackani's Avatar
Default V3 Big Bore shock adjusters
Has anyone else noticed the shock preload adjusters have no drag on the threads like ones that normally have a rubber seal in them? I am concerned the adjusters are moving during racing. The book mentions aluminum but mine only came with the plastic on the 410 for some reason.
jmackani is offline
Old 01-01-2012, 07:11 PM
  #8907
the hot wires right around 30 dollars. but as of now you cant yet update the vipers without sending them in to get the firmware. vs tekin that you can download and install with the hotwire currently.
cm.stites is offline
Old 01-01-2012, 07:58 PM
  #8908
jmackani's Avatar
In addition, if a new feature becomes available, you get it for free from Tekin. I am willing to bet they will charge you for a new programming card or require you to upgrade the viper. Tekin has done this quite a bit in the last few releases with items like push control, roar timing profiles, etc.
jmackani is offline
Old 01-01-2012, 08:44 PM
  #8909
Tekin it is then. I'll just run it with the stock profile until I have enough to get the hot-wire. How are the tekin motors? I'm going to be using a 6.5
Old 01-01-2012, 08:49 PM
  #8910
I run a RS Pro 8.5t Combo and its smooth and wicked fast.
Walkman is offline
