Team Durango DEX410 4WD 1/10 Off-Road Buggy Thread
do tell
I was racing last night and can't figure out how people break these cars. I had a couple occasions I has going WOT down a short strait and clipped the pipe sucked the car right in with out breaking. I saw Schumacher and Yokomo cars to the same and break arms instantly. The 2wd buggy is the same, by far the strongest cars I've ever driven.
I clamp down to hard with vise grips to move the collar I mess up the body
I was told by lhs the make metal shock towers? dint see them on there site or a main
i know mine came with thick metal ones.
i have a dex410rv3 that i upgraded. i like the metal towers. give me a minute ill get you numbers
I've bent my front roll bar a bit so I'm looking to replace it. I don't mind bending my own, what do you guys use for bulk piano wire and where do you like to buy it? links please!
Thanks!
Thanks!
what are some good hop ups to get iam new to the 410 line
TD320007 Brass Skid Plate 30g weight
TD330311 Servo Saver Arm
Aluminum Servo Arm for your Servo.
TD310208 Diff Loop is a upgrade that I run, as a previous v2 owner, I lost a few plastic ones. But they strengthened the part in v3/v4.
TD310226 Alum 14mm hexes are nice to have too.
if you have issues with breaking front arms and broken inner hinge pins get some 91595A146 3mm pins from McMaster and dremel them to fit.
what gearing for a 6.5 ?
i would say around a 20t for outdoors i used 21-22t for 7.5
