Like Tree22Likes
Old 10-03-2010, 07:29 PM
  #2146
mike881's Avatar
Where are u using loctite? I'm breaking the piece that ends up connecting to the servo. My servo saver isn't coming loose...
mike881 is offline
Old 10-03-2010, 07:33 PM
  #2147
Konich's Avatar
The servo horn?
Konich is offline
Old 10-03-2010, 07:37 PM
  #2148
mike881's Avatar
No, the servo horn is connected to a link which is connected to the servo saver... Make sense? The servo saver is what's breaking. Part 340007
mike881 is offline
Old 10-03-2010, 07:47 PM
  #2149
Trader Rating: 104 (100%+)
Yeah i only see ones that sold anyone hit my up with what you got and wanna get rid of. Give me a price of what you want and we can go from there.
Ostach24 is offline
Old 10-03-2010, 08:05 PM
  #2150
dangerwr's Avatar
Which one? There are 3 parts with that number. I guess you mean the top one on the servo saver side? BTW, did you set your end points on the throttle servo??
dangerwr is offline
Old 10-03-2010, 08:15 PM
  #2151
mike881's Avatar
You mean steering servo? Yes I did set the endpoints. And it's the piece where the link connects the servo horn to the servo saver. When you installed it, it's the piece where the servo saver spring sits into. It's hard to explain this over the computer sorry!
mike881 is offline
Old 10-03-2010, 08:19 PM
  #2152
Trader Rating: 21 (100%+)
i'm done with the dremel on the center diff housing...thx to the guy about this trick!now the cover is going down very well on the bearings! so the U pin is going in and out freely!
mccoy is offline
Old 10-03-2010, 08:47 PM
  #2153
dangerwr's Avatar
I gotcha now. Weird! You might be the only one in the world with this issue. I dunno! And you say the aluminum steering plate is nudging your steering servo? Maybe you could shave off a little material from the steering plate? I am sure it is plenty strong. Just an idea. I have another idea that is more complicated and requires you to put spacers under the entire servo subassembly to raise it up a bit . . .
dangerwr is offline
Old 10-03-2010, 10:07 PM
  #2154
littlejohn's Avatar
I broke 3 servo savers today. One time I hit a pipe the other two were when I landed and none of them were extremely hard at all!!! But I think I've narrowed down why. My servo seems to be too high for the black aluminum brace above the servo (not sure what its called). I tried moving my servo down as far as I can but its not fixing the issue as it still scrubs it a little. When I move the wheels with the servo disconnected, it doesn't move as freely as my other cars do. Could this affect the servo saver? because otherwise idk what to do.
I'm running a JR9100s.
Please, any suggestions
Yup.. I lightly sanded / dremeled part of my servo case and a bit of the servo saver that was making contact. I think the JR9100s are a tiny bit thicker that other servos.
littlejohn is offline
Old 10-04-2010, 06:09 AM
  #2155
RETRO R/C's Avatar
Trader Rating: 57 (100%+)
That's a pleasure - anything for a fellow "Ranga" driver!!
Cheers
Darryn
RETRO R/C is offline
Old 10-04-2010, 06:58 AM
  #2156
grapejuice's Avatar
Trader Rating: 153 (100%+)
It must be cuz I got a 9000s to fit...
grapejuice is offline
Old 10-04-2010, 09:32 AM
  #2157
here is my durango big bored out
shifter is offline
Old 10-04-2010, 09:53 AM
  #2158
Konich's Avatar
Who's big bores? Those look mighty tasty!
Konich is offline
Old 10-04-2010, 09:54 AM
  #2159
grapejuice's Avatar
Yokomo's
Old 10-04-2010, 10:16 AM
  #2160
Originally Posted by grapejuice
Yokomo's
yup
shifter is offline
