Like Tree22Likes
Old 10-04-2010, 04:49 PM
  #2176
Konich's Avatar
I'll be there Wednesday. I'm hoping my durango diff fluid will be in as I'm going to swap out the rear diff and put in the new 2.0 drives as well. I also have to finish up mounting my Azashari body as well.
I really need to track down some new lipo's though before this fall season kicks off.
Konich is offline
  #2177
Bman's 3XNT's Avatar
Trader Rating: 71 (100%+)
Originally Posted by Dlewis4
To the guy who just bought the 2010 spec....
soften the car up right away...
go 10-3 or 7-3 in the diffs, light green springs in front, dark green in the rear, 35/30 shock oil, 3 hole pistons all around. That will be a good starting point, especially if you are running on high bite tracks.
B-Man, a shorter rear link will let the rear end come around more, I would try sticking with the long link and getting the 1* rear hubs... best of both worlds
Thanks. On the springs is that what you run? I thought it was opposite, light green rears and dark green fronts. One step lighter on both ends. Just a question, thanks again.....
Bman's 3XNT is offline
Old 10-04-2010, 05:00 PM
  #2178
Dlewis4's Avatar
Trader Rating: 148 (100%+)
Hmm... Now you got mr thinking. I will check when I get home. All I know is making the car softer made it oh so much better to drive. I picked up 2 laps with this car compared to my B44
Dlewis4 is offline
Old 10-04-2010, 05:02 PM
  #2179
dangerwr's Avatar
I got those Team Orion saddle packs. The 4500mAh are 24.5mm tall though. You can get them with Deans but is a bunch of wire that you may not want. They sell ones for bullets, or as they call them "tubes," that might work better for you. They fit perfectly in the 'R' version. They are 45C and freakin' rip!!
dangerwr is offline
Old 10-04-2010, 05:34 PM
  #2180
R-E-A-P-E-R-'s Avatar
Danger did you get the lipos with the wires permanently attached bud?
R-E-A-P-E-R- is offline
Old 10-04-2010, 05:36 PM
  #2181
Konich's Avatar
Man that is ROOKIE right there
Konich is offline
Old 10-04-2010, 05:39 PM
  #2182
dangerwr's Avatar
Define permanently! But yeah, they are wired to the cells inside the case. I opted for these since I had a little trouble in the past with those tubes that are soldered directly to the cells . . . and they had the Deans already wired up. The leads are quite long for the Rango and they use a 12 AWG wire that looks more like 10 AWG with the silicone jacketing. Nice packs though. I give them an 'A.'
dangerwr is offline
Old 10-04-2010, 05:40 PM
  #2183
dangerwr's Avatar
Me? ROOKIE?? This ROOKIE is gonna lap you too in NOOOOOOOOOOOOOOOOOO time son!
dangerwr is offline
Old 10-04-2010, 06:01 PM
  #2184
Guys for a little more rear on power traction, should I go down on the oil? It seem the rear always washes out when I try to get on it. I tried the slipper but when I get in trouble I can't clear certain jumps. Heavier oil makes it more posi, correct? Thanks.......
Old 10-04-2010, 06:11 PM
  #2185
Corey Bernardo's Avatar
heavier oil in rear will gain more rear traction and lose a lil steering...
Corey Bernardo is offline
Old 10-04-2010, 06:18 PM
  #2186
dangerwr's Avatar
I guess it depends if you are talking about in the turns or down the straight. Let us assume you are talking about in the turns since in a straight line the gears are locked. I surmise the idea behind a differential is that one side is turning different from the other. The thicker the fluid the more resistance you will have--no mystery there. If you are "diffing out" it is because you are running too thick of fluid. A thicker fluid will be slower to lock the gears back up--the outside wheel takes longer to catch up. So, the result is that on power traction is compromised. So I guess go thinner? What are you running now??
dangerwr is offline
Old 10-04-2010, 06:25 PM
  #2187
Matt Howard's Avatar
I'm going to have to respectfully disagree. Every car I've driven, this one included, gains rear traction by lightening the rear diff action. Obviously if you go too light you'll diff out but anything around 2k-3k in the rear should be fine if your looking for more rear traction.
Matt Howard is offline
  #2188
Coming out of turns, and going down the straight. I tried 2,3,5 all seem about the same. I know the heavier will make it turn less, but what about on power? I thought lighter oil would let the wheel with more traction hold up and let the wheel with less traction spin, there for gaining a straighter acceleration, not fishtailing. The heavier the more the rear will kick out. Is this theory right?
Old 10-04-2010, 06:27 PM
  #2189
Bman, are you running any weight in the rear? I run the rear brass skid plate and my rear is fine with the 3k in the diff.
Old 10-04-2010, 06:28 PM
  #2190
Just the side plates. I am going to run 2k this week to see if it helps.
