Like Tree303Likes
Team Scream Racing
Old 05-02-2017, 12:04 AM
  #1501
Default Timing and gearing
Hi guys. I'm looking to find the right timing and gearing for my TSR the one 17.5. I will be using it for my touring car on a 90x45 indoor carpet track. Thanks in advance
Yolks_r55 is offline
Old 05-02-2017, 04:19 AM
  #1502
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
We typically start around 46* and a mid 4.2 FDR
If the track is technical go to a mid 4.3 FDR and 48 to 50*
sg1 is offline
Old 05-02-2017, 05:11 AM
  #1503
Thanks Sg1 I will definitely try that. One more thing tho, what's the max temp should I expect with this setup?
Old 05-02-2017, 05:21 AM
  #1504
sg1
sg1's Avatar
With a good fan we saw temps from 130 to 150*F depending on traction and driving style over the weekend.
sg1 is offline
Old 05-02-2017, 06:06 AM
  #1505
Thanks!
Old 05-02-2017, 06:17 AM
  #1506
sg1
sg1's Avatar
Thanks!
No problem!
Spot check temps after 2 minutes
If the car lunges way at the end of the straight and feels soft off the turn drop a gear.
If it lacks top end go up 1
Yolks_r55 likes this.
sg1 is offline
Old 05-02-2017, 06:01 PM
  #1507
jdawg81's Avatar
Does this also apply to the 21.5 motor or does this motor need different gearing compared to the 17.5?
For an outdoor track that's about 180 x 80 ft what would be the recommended gearing to start with for for the 21.5 motor in a touring car?
jdawg81 is offline
Old 05-03-2017, 04:20 AM
  #1508
sg1
sg1's Avatar
For 21.5's on larger outdoor tracks try starting at 46* on a motolyser and a 3.4 to 3.5 FDR.
I have feedback from some guys who have gone to a 3.1 to 3.3 FDR at 48*, but start off safe
sg1 is offline
Old 05-03-2017, 04:36 AM
  #1509
Super Moderator
Marcos.J's Avatar
Trader Rating: 239 (100%+)
Large outdoor track 3.39fdr at 51degrees it's a rocket with a r1 fan comes off the track about 138degrees that's in the Florida heat. Timing at 51 on a motolyzer
Marcos.J is offline
Old 05-03-2017, 04:43 AM
  #1510
sg1
sg1's Avatar
The TSR may generate a bit more heat at 51 then the R1.
If traction is down some you may get away with it
sg1 is offline
Old 05-03-2017, 04:44 AM
  #1511
Super Moderator
Marcos.J's Avatar
It's a TSR motor with an R1 fan blowing on it traction was never down
Marcos.J is offline
Old 05-03-2017, 04:58 AM
  #1512
sg1
sg1's Avatar
Gotcha! That's alot of gear and timing...lol...
You're chassis must be spot on!
sg1 is offline
Old 05-03-2017, 05:03 AM
  #1513
Super Moderator
Marcos.J's Avatar
For sure! my drivetrain is pretty free , zero drag brake
Marcos.J is offline
Old 05-03-2017, 07:39 AM
  #1514
JAE
Trader Rating: 30 (100%+)
Is it best to leave timing where it is set at for 2wd buggy? Run on both medium sized and small track and the small track I drop 2 teeth in pinion. I ask as I've had other brand motors whose sensor board deviations jump when adjusting the timing board. Currently my motor is set at 44 degrees. Is there an optimum timing/or amp draw for 2wd applications or best served just leaving timing as is? Thx all
JAE is offline
Old 05-03-2017, 08:05 AM
  #1515
Super Moderator
Marcos.J's Avatar
maybe but im running tc not 2wd buggy
Marcos.J is offline
