Like Tree886Likes
TLR 22 5.0
Old 05-16-2019, 09:34 AM
  #706
Pistol123's Avatar
Originally Posted by fat500
anyone move the shocks to the rear of the arms and flip the tower? Thoughts?
It's good if you need more grip and I have used it on the 4.0 on wet slippery astro but I prefer keeping them on the front and adding the 25g rear weight as it keeps the weight within the wheelbase.
Pistol123 is online now
Old 05-16-2019, 09:44 AM
  #707
I appear to have joined the ranks of people having problems with the shocks. Was cleaning it after race day 3 and found this. I didn't crash it, or even hit any really big jumps or anything. I had read that some people were breaking the end caps in different places.
Darkstorm05 is offline
Old 05-16-2019, 04:37 PM
  #708
fat500's Avatar
Trader Rating: 51 (100%+)
Tks, I will try it and see. Gonna ck my shock ends now.....................................
fat500 is offline
Old 05-16-2019, 08:27 PM
  #709
thirtydaZe's Avatar
Trader Rating: 39 (100%+)
where are you reading that this issue is piling up? First ive seen anything about it. Just curious if there is another source of 5.0 info that im not apart of.
thirtydaZe is offline
Old 05-16-2019, 08:50 PM
  #710
Default Great Astro car!
No issues with shock rod ends. No issues at all actually!
Racing on high bite Astro. Up to speed immediately with few changes.
Car was an easy build; far better than the 4.0 I had. Great fit and finish. Still no suspension slop after the equivalent of four race nights and I’ve broken nothing.
i am going to try the brass front pivot block. Wish there was a slightly lighter one.
Anyway, if you had a 4.0 and weren’t happy with the build, don’t worry. This kit is great!
4wdfull is offline
Old 05-16-2019, 11:23 PM
  #711
I_NeedBigDrink's Avatar
Don't have any issues with rod ends either. I decided to change things up. Switched the direct drive for a slipper, added +2mm towers, low front wing, new bearings, some titanium motor screws, and swaybars to see how they affect handling. I know buying option parts is unnecessary, but I love testing stuff out and tinkering at my desk
Also I'm taking an engineering graphics course and for my final assignment i decided to model a front G3 shock! Was a neat project and learned some new techniques.
I_NeedBigDrink is offline
Old 05-17-2019, 05:38 AM
  #712
I'm in a TLR 22 FB group. There was a thread when the kit first released where a batch of people were posting pics of them losing the end piece. So far though this has been my only issue with the kit. I love it, and it is a great upgrade from my 4.0. Given the spot where the end broke, I'm going to assume that the poor thing couldn't withstand the force of all that extra high speed cornering the 5.0 opened up on carpet tracks.
Old 05-17-2019, 06:13 AM
  #713
Nice job. For a better grade you might consider moving the text from part number to the description field and either use TLR part numbers or make up your own in part number column. Good luck.
I_NeedBigDrink likes this.
Roken is offline
Old 05-17-2019, 08:12 AM
  #714
I decided to change things up...low front wing...
Just curious, but, have you had the chance to compare how the buggy handles, comparing the stock front wing vs no front wing vs low front wing, especially on dirt/clay? I've seen a couple people running the stock front wing (as I have), and some running without any front wing, but I haven't seen anyone (yet) running a low front wing.
Panther6834 is offline
Old 05-17-2019, 10:22 AM
  #715
Just installed the parts yesterday, so no chance to test yet
I figured I’d try it out because I have a feeling the high front wing disrupts enough air flow to the rear wing to make a noticeable difference. I’ll see how it handles the fastest turns on the track. Another reason I got it is because it less of an eye sore and hopefully will last longer in the lower position.
Old 05-17-2019, 10:26 AM
  #716
That’s a much better way to write the BOM. Thanks for the feedback!
Old 05-17-2019, 03:57 PM
  #717
Trader Rating: 19 (100%+)
What size drill bit are you guys using to drill out the ballcup
speed101 is offline
Old 05-17-2019, 08:14 PM
  #718
SCRAFAN's Avatar
Trader Rating: 22 (100%+)
Have you tried cutting the wings down some? Might have the most effect of all.
SCRAFAN is offline
Old 05-18-2019, 09:20 AM
  #719
thirtydaZe's Avatar
EDIT: never mind, I think we are referring to 2 different thing. I was just making a hole in the cup for easy access to the ballstud.
I drilled one of mine out yesterday and used a 2 mm bit. i had to "massage" it a bit to get my driver into the hole. That said, i haven't put it on the turnbuckle, or popped it on a ballstud, so i can't comment on how or if it works.
Old 05-18-2019, 03:30 PM
  #720
Team Pink's Avatar
Trader Rating: 20 (100%+)
Going between the three I would say the lower front wing option is more aggressive overall in the low speed sections of the track, whereas, running the wing up high tends to give the car more predictability in high speed sections (i.e. sweepers, etc...). For the most part I always run a front wing indoors, but there has been circumstances outdoors on lower bite tracks that running neither has been better as it actually made the buggy easier to drive.
Team Pink is offline
