Team Associated TC5 >
Team Associated TC5
Team Associated TC5
Old 07-29-2008, 09:19 PM
  #6691
hanzo3's Avatar
Trader Rating: 55 (100%+)
What is the cheapest, fastest metal gear servo to use with the TC5? JR Z590M? Racing on a budget. How about brushed ESC?
hanzo3 is offline
Old 07-30-2008, 07:43 AM
  #6692
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Originally Posted by Skip109
In my best Bob Stellflue voice
O Canada!
Our home and native land!
True patriot love in all thy sons command.
With glowing hearts we see thee rise,
The True North strong and free!
From far and wide,
O Canada, we stand on guard for thee.
God keep our land glorious and free!
Don't give up your day job. 50,000 comedian's out of work and you are trying to break into the business.
Kraig is offline
Old 07-30-2008, 07:47 AM
  #6693
BobbyS's Avatar
Hitec 645MG and Futaba S3305 are both solid servos for around $35.00, the DuraTrax IntelliSpeed and Associated AI Quantum Runner are good $40.00 ESC's for 18T and up motors.
BobbyS is offline
Old 07-30-2008, 09:01 AM
  #6694
Haha I can totally hear bobs voice on that one. thats pretty funny.
Keven H is offline
Old 07-30-2008, 09:25 AM
  #6695
seaball's Avatar
keven,
welcome to the team.
seaball is offline
Old 07-30-2008, 09:30 AM
  #6696
StephenSobottka's Avatar
I can see all you cloakers out there...hehe
StephenSobottka is offline
Old 07-30-2008, 11:29 AM
  #6697
PartTime's Avatar
Hi guys. Maybe you can help me. I set up my TC5 to the new stock rubber setup. Love the way it feels and handles. Very neutral and easy to drive fast. BUT, the inside of my tires, all 4, are wearing like sorax's do. You know how you get the line that cuts threw the tire? These are take off tires. I started with the book setting of 1.5 or 2 degs on camber. I noticed the wear and knocked it back to 1 deg all around. It was still wearing on the inside so now Im at 0 degs all around. I have a new set of tires to try but wanted to wait and see if maybe somthing can be done?
I used a china marker and put a line on all the tires. Took a lap and checked to see if they are wearing evenly and they are at 0 degs. They seem to be the same.
I have the 2A lower blocks in. Think maybe the 3A blocks would be better?
Here is a pic. Kinda hard to see though.
DK
PartTime is offline
Old 07-30-2008, 11:49 AM
  #6698
AE-Reedy
DK
I would say the line is usually caused by the insert in the tire. Thin inserts let the tire move more and will cause the wear pattern you are describing.
Sean Cochran is offline
Old 07-30-2008, 12:06 PM
  #6699
PartTime's Avatar
These are take off pre mounts. I know thats why the sorax tires do it, you can feel how baggy the tire is over the insert. But the take offs are a lot tighter.
DK
PartTime is offline
Old 07-30-2008, 12:24 PM
  #6700
artwork's Avatar
Trader Rating: 88 (100%+)
Sean, but why would it happen just on the inside?
I have never seen wear like that on the outside!
artwork is offline
Old 07-30-2008, 12:35 PM
  #6701
BobbyS's Avatar
No expert here, but I agree. After seeing that on many, many tires that I'd glued together myself. Centrifugal force <and voodoo> causing the insert to ride up.
BobbyS is offline
Old 07-30-2008, 12:40 PM
  #6702
artwork's Avatar
I hate it when my inserts ride up!
artwork is offline
Old 07-30-2008, 01:20 PM
  #6703
beavis353's Avatar
beavis353 is offline
Old 07-30-2008, 02:52 PM
  #6704
PartTime's Avatar
So just set the camber to 1deg and see how it feels? Forget about the tire eating itself?
I was thinking that, cause of the roll center being low it was tipping the inside tire over enough to dig into the inside edge. Maybe even a little wheel spin was helping it?
DK
PartTime is offline
Old 07-30-2008, 03:35 PM
  #6705
AE-Reedy
DK
Yes just set the camber to the best setting then rotate the tires to extend their life. The ridges form on the fronts more quickly than the rears. I think as the tire rolls over and the side wall is stiffer it wears in that corner joint. If you have a thicker insert in the tire the tread portion of the tire can't move as much and it should wear as much better.
