RC10B4.1 FT/WC
#6166
The wheelbase with a +12 chassis on a B4 is 285mm. The T4 chassis is 288mm and the B4 is 273mm. So the T4 is 15mm longer than the B4 chassis. Start with cavaleri's worlds setup. Should get you pretty close, then fine tune from there. I am running pretty close to that but have changed oils a bit, F orange /R dark yellow kyosho springs.
#6172
I built myself a +8mm B4 and found that any and all B4 bodies should fit.
I am still using the stock original B4 body on mine and it fits like a glove, plus it's stealthier since people don't realize it is a modded chassis.
I prefer the look and feel of the stock original bodies over the cab forwards as well.
#6175
#6177
I honestly believe most all of the bodies SHOULD fit nicely with the +8mm chassis. I tried 3 different short B4 bodies and they all fit perfectly with no problems at all.
In other words, no need to buy a "long" body for your 8mm longer B4-B4.1 buggies.
If the standard and other short bodies work, then most all of them will work. I find it hard to believe otherwise.
I didn't have to trim anything off my stock short B4 bodies either, from running the same body on the standard chassis.
Now if you have got one longer than 8mm, then I cannot speak as I haven't tried longer than +8mm.
#6178
Any of you guys gonna be at the Jconcepts race in MA this weekend? I wanna try to slap my body on a +8 chassis and see how it fits. I've been holding off from getting a +8 chassis but I think it's almost time with the indoor season coming up.
#6180
