which way should they be oriented? notches pointing up or down? I tried both ways a few times with zero luck.
Fri Nite Race Report...Got beat up on by Jayson (NITROLUVER)Englsih LOL
Fun racing, usual Story, nothing broke nothing bent Yada,Yada blah,blah.
Jayson is a great driver and really had the groove all night! Good job Bro!!!
It was nice to have a full heat of 4x4 sct tonight Hacks and All!
When running the new TLR chassis with the center diff mounted directly and with with no plugs, do the holes in the chassis need to be covered to prevent dirt from entering?
I normally run indoors on clay only but was wondering what the other guys are doin?
What 2nd page oh no!!
Hey guys heres a little mod i did, figured some may be interested... The body obviously takes a beating and cracks along the front fenders making the body even weaker eventually you can push down on the roof and the front end opens like pac-man!.... so i took two body mounts i found in my "junk" box ((not sure where they came from)), two nuts and two 5-40 1 inch set screws and did what you see in the pix.... makes a huge difference, it helped even way more than i thought!!
-No more cracking on the fenders...
-Body won't open up like "pac-man" at high speed...
-Truck won't sound like a trash bag of spare lexan hitting the ground after jumps!
-Can push down on the roof with no body flex.. feels like it has a roll cage!
Anyways thought i'd share the idea... i thought it would look kind of "hack" but acctually does'nt look to bad either
Raced offroad carpet last night and got second in both heats and placed second in the main. I was pretty happy since I'm not a pro nor am I a sensored driver
I finally got around to cleaning the grease out of the diffs. After cleaning the front one out and refilling with fluid, it seems to really notchy when turned by hand, as far as I know, everything went back in the way it came out. Did I screw up, can the screws be too tight, it there a way to adjust it? Thanks
Most likely the cause is that the gears aren't fully seated in the diff case. Open it up and push down on the top two gears (like one thumb on each gear).
I tried that, it seems to be better but not perfect. Do these smooth out when you run them after everything finds it's spot? I just don't want to put it back in and have to pull it out again, the front one is a bit of work to get to. Thanks again.
While I'm asking questions, is 5/5/3 what everyone is getting the best results on a high bite clay track with? This is totally different than setting up my truggy.
I bought a second truck to set up. Anyone wanting to part with an SNR or BCE chassis please hit me up with a PM.
Does anyone know if the SNR 3.7 CF chassis is milled out on the top side (For like the receiver box etc) of the chassis or is it completely flat like the bottom is? I just ordered one to try it out, decided I enjoy driving this truck so much that I should build another one Also what's a good starting shock setup on the stockers for 1/8th scale track with good traction that's somewhat smooth? I run the big bores on my other one but since I'm going lighter on this truck I figured I'd stay with the stockers running emulsion and see how they compared. Lots of goodies on the way
I have reviewed the exploded view of the manual about 20 times and have the notches the correct way. As you can see in the picture, I am able to get one side in the correct notch, but the other side is a little bit longer. thoughts on how to fix?
