#5732
Guys , Great idea putting that info on the first page .. just all around good topics here . It's saves a lot of hours . I raced the truck last friday night. Raced on sunday too. TQ'd and the won the A-main both days. All I did was add diff. oils. everything else came from all of you guys putting forth your experiences . Thank you
#5734
I'm curious about some of the issues guy's are having. I read posts about things breaking, specifically premature wear of the outdrives and cracking plastic, broken/cracked drive shafts.....ect. I have 20+ packs on mine and only changed out the diff pins. My plastic still looks new and outdrives show no wear at all. Are the guy's breaking parts actually racing on dirt?? or bashing in the yard or pavement?? Just curious.
#5735
#5737
Curious if you noticed the bent driveshaft syndrome that myself and others had noticed new from the box with your driveshafts also prior to having this failure? My rear shaft has a serious wobble and I havent even run the truck yet.
#5739
First off torque with brushless motors are more a function of your battery than any gearing you could ever throw at it.. so don't go there. These are not brushed motors 2 teeth on a spur will do nothing for torque or effeciency in fact effective torque will go up as you gear up (smaller spur, larger pinion) as long as your temps are not going over max and your lipo can handle the load. Now that we have that out of the way you can understand why all this work to get any different spurs for effeciency that isn't there is all a load when dealing with brushless systems and lipo's. You will only reduce temps and increase run time by gearing down (raising total ratio) so if you increase a spur or reduce your pinion you will reduce your top speed, increase run time and normally reduce motor temps on most tracks. I say normally because yo can go too low and this will result in creating heat as well. This is my story I'm sticking to it because it's right. I will say if your motor is too close to your center diff like the other guy a change in spurs could be helpful on that aspect but trust me I've geared all sorts of different combos to get the same ratio and with a brushless motor and lipo you don't feel any difference unless the ratio is different.
You are validating that a larger spur increases low end torque when you agree that a larger spur decreases top end.
I will agree though that it is not as dramatic as in a brushed setup but to say it is not so is to digress as well.
#5743
I know just I found this one
http://www.hobbyking.com/hobbyking/s...dProduct=16243
Looks really good?
Actualy I have one that is 178 oz in there now , it seems to work good I doubt I need any more actualy ?
Or I was going to get the
Savox SC-1256TG
Looks really good?
Savox SC-1256TG
#5744
I know I'm sure others are bored.. I’ll stop on this tangent as well.
