Tamiya TRF415
#1861
JRRobiso,
Have you ran your 415 yet? I just finished my first ever pack on mine, and all I can say is WOW! This car feels planted from the get go... only thing I changed so far from the kit setting is to stiffen up the front one step with the blue springs... the kit setting is too soft up front for my driving style...
(btw, this is eeyan disguised as dyaz... he needs to catch up on his posts...
#1862
Originally posted by dyaz21
JRRobiso,
JRRobiso,
Nope, making some fine adjustments to the car. I'm about 98% done (need new rear holes for my existing body that I use on my 414M). Bought new motor today (Monster of Touring) and discharge tray by Integy. My 3300 mah batteries only go up to 2600-2800 mah when I charge them. The only hop-up parts I added to the kit was the blue alum cyclinder nuts & blue spring ret. Will post some pics when I get a chance.....
#1863
Originally posted by KilRuf
You think so? Are they different than the screws that were in the 414? I just remember people stripping them out and having to dremel the screw heads on the 414. I didn't take the risk.. so I'm using Ti screws on the lower deck.
If you are only using part Ti screw, you should use them for the upper deck. Keep the steel ones in the bottom for lower CG.
#1868
NVisible a friend is midway through the reanodizing of his right now. I would look to an outside source to do the parts it is labor intensive. They parts need their original ano stripped off and then re-polished.
#1872
Paul it is close but not exact. Look back in the pages here some one had a link to Ling's rate chart. It might be in the Evo thread
dway-yes it wil add sweep to the front arms if used with the front/front d block. As far as availibility if you are in the US, not overseas you might find it.
#1873
I've never really stripped the screws on my 414M2 or Evo3. I learned from reading here hehe. I just tighten them down and use thread lock to secure them. But I didn't want to take the chance with this kit. Plus Steve Wang is a great guy... so I got some Ti screws from him..
Oh... and not to mention.. I like how Ti sparks on asphalt track sometimes... hehe
Well ran the 415 today. It did pretty good. I'd still like to try a few things though on it. I ended up using my Yok SD for the main just to get some lap times on it.. and well... that was a bad mistake. It was almost a sec off pace. I gotta get that car setup right again. Gonna toss the CGM chassis and put on the RaySpeed back on. Then I can make some more accurate comparisons between the cars.
Anyways, got some more tweaking to do.
Oh... and not to mention.. I like how Ti sparks on asphalt track sometimes... heheWell ran the 415 today. It did pretty good. I'd still like to try a few things though on it. I ended up using my Yok SD for the main just to get some lap times on it.. and well... that was a bad mistake. It was almost a sec off pace. I gotta get that car setup right again. Gonna toss the CGM chassis and put on the RaySpeed back on. Then I can make some more accurate comparisons between the cars.
#1875
well, thought id report on my front diff deal... works as planned, no problems at all. very hooked up on our surface here, just gotta fine tune setup. now, i gotta go order the second locked pulley to finish the job.
3Likes
i'm about to check tower/speedtech. what belt tension are you guys running ?
