Old 06-11-2004, 01:08 PM   #2611
rtypec's Avatar
Hey JR, I need to find a one-way setup in the next couple of weeks as I don't believe that reedy race setup will work very well with one-ways installed. As for gearing, I'm not sure on that one either, maybe Charlie or Corey Lewis can fill you in on that as they were both ballistic.
rtypec is offline   Reply With Quote
Old 06-11-2004, 01:33 PM   #2612
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Default Thanks Rod for the reply.
I did forget to mention that I run a front spool on my 415. Ran the car w/monster stock motor and handled way, way better than the 1st time I ran the car w/ 1-ways front & center. The only adjustments I made was lessen DR on the steering and no using of brakes. The front spool made a big improvement on the handling of the the 415 w/c sort of surprised me condsidering I still had the center 1-way.
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 06-11-2004, 01:34 PM   #2613
Hebiki's Avatar
Trader Rating: 26 (100%+)
Default Re: GEARING FOR 19T SPEC MOTOR
Originally posted by JRRobiso
GEARING INFO
I going to race the 415 w/ a 19T Spec motor. But not sure what the appropriate gearing needed for the track I will soon race on. The track at my LHS pretty much resembles the track layout of the Tamiya, CA (RROC'04). The spur gear I'm using right know is a 102T-64P and pinion size is 31T-64P which according to the manual gives the final gear ratio of 7.20.
Would the gearing be suitable for the track I'll be racing w/ medium bite as well? Set-up of the 415 is similar to Rod's (RtypeC) set-up used at the RROC'04 except w/a center 1-way layshaft (still working on that part but might as well wait for the one Tamiya's coming out with) and stock front bridge suspension mount D.
Any info re gearing will be appreciated. Thanks!
Jun... i have a set up for the 415 for low/med bite tracks. ill PM it to you... the track though had an extremely fast layout. my FDR was 5.8 for a reedy 19T quad mag (fixed timing). i was using a 78T spur (48P) and 29T pinion. my car was very fast too bad my driving couldnt keep up
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-11-2004, 01:51 PM   #2614
JRRobiso's Avatar
Default Re: Re: GEARING FOR 19T SPEC MOTOR
Thanks Chris. But w/ that FDR you had, would'nt that fry your motor? The 19T x 1 motor I'm running is a BIRDMAN/Trinity one. Don't know if that would make a difference.
Old 06-11-2004, 01:54 PM   #2615
Hebiki's Avatar
Default Re: Re: Re: GEARING FOR 19T SPEC MOTOR
nope.. didnt fry mine... there were other guys who were geared higher... around 5.6. it does kill the brushes tho. ill try to find a picture of the track we ran on. it was very fast (lots of long straightaways) and only one spot where we had to let off to about half way on the throttle.
Hebiki Design Works
Old 06-11-2004, 02:07 PM   #2616
Martin Crisp's Avatar
Default 415 one-way setup.
Hey Rod,
I saw you were looking for a one-way setup....here is one that Surikan used.
Setup: 415 rubber outdoor - Surikan's
Front :
springs : Assoc Gold - 40 w 3hole
sway bar : yellow
shock mounting position : 2nd hole in from outside on shock tower. outer hole on a arm.
uptravel : 2mm
front one way : yes and center oneway
Kickup : none
Upper Arm : Low rc - 4mm spacers under innner link. No spacers under blocks
Left : C2
Right : C1
Caster : 4 degrees
Camber: -1
Wheelbase: all the way to front
Tires:??
Rear:
springs : Assoc Silver 40 w 3 hole
sway bar : yellow
shock mounting position : outer holes top and bottom
uptravel : 2mm
Anti-squat: none - and no spacers under either block
Upper Arm : medium 2mm spacers under inside link
Toe in: 1 degree upright - with 2.0 total toe (a/c).
Camber: -1
wheelbase : all the way forward
Body : Mazda 6
Motor: 8T
Gear : 103 27
Here is a setup I used on carpet....
Rc: Setup 415 rubber carpet oneway
Front :
springs : yellow
sway bar : yellow
uptravel : 2.5mm
front one way : yes
Kickup : none
Upper Arm : high rc - no spacers under innner link. No spacers under blocks
Caster : 8 degrees
Camber: -1
Wheelbase: all the way to back
Tires: cs 22 - med insert
Rear:
springs : yellow
sway bar : yellow
uptravel : 2.5mm
Anti-squat: one .7mm spacers
Upper Arm : 4mm spacers under inside link
Toe in: 1 degree upright - with 2.5 total toe (a/d).
Camber: -2
Martin Crisp
Power-Story.com | LearnSetup.com
Martin Crisp is offline   Reply With Quote
Old 06-11-2004, 02:14 PM   #2617
JRRobiso's Avatar
You do have a point there Chris... Track layout also determines the gearing/FDR as well. This is all new to me 'coz it's actually my 1st time to run a 19T motor. I'v been running stock ever since I started racing, but nowadays the guys @ my LHS have upgraded to the 19T class. Nobody (the last time I raced) was running stock anymore & I had to race that day w/ a 19T on my TRF414M SSG w/c I got the gearing info from the 414M thread. Did pretty good for my 1st outing w/ a 19T motor.....3rd place - B main.
Old 06-11-2004, 02:15 PM   #2618
Hebiki's Avatar
Default Re: 415 one-way setup.
Originally posted by Martin Crisp
Hey Rod,
Martin, thank you for the set up info!
Hebiki Design Works
Old 06-11-2004, 02:23 PM   #2619
s2
s2's Avatar
Martin......what shell were you using indoors?
s2 is offline   Reply With Quote
Old 06-11-2004, 03:33 PM   #2620
JRRobiso's Avatar
Thanks again for the set-up you PM'd. Will try the set-up & see what happens.
Old 06-11-2004, 03:38 PM   #2621
Rick, where do you race indoors mate?
Evo_Uk is offline   Reply With Quote
Old 06-11-2004, 03:45 PM   #2622
Hebiki's Avatar
no guarantees on that set up. my driving style seems to be very opposite of everyone elses...
you'll get one of two reactions....
= dialed
or
= hurting
Hebiki Design Works
Old 06-11-2004, 03:48 PM   #2623
JRRobiso's Avatar
= dialed
or
= hurting
Old 06-11-2004, 03:52 PM   #2624
Send a message via AIM to Dougnuts55
Hebiki will you get on aim
Dougnuts55 is offline   Reply With Quote
Old 06-11-2004, 03:57 PM   #2625
Hebiki's Avatar
cant buddy. im still at work. you can PM me...
Hebiki Design Works
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
