Like Tree2Likes
Tamiya TRF415
Old 08-23-2004, 04:48 AM
  #3361
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by TryHard
Anyway,
Has anyone tried the Subaru legacy B4 on their 415's yet? how do they handle? what's it similar too (ie vectra, dodge2 etc). I'm curious as I've just ordered one from R10
Regards
Ed
THe B4 has almost the exact same handleing trates as a Yokomo Type "D" body or a little bit like the HPI aero2
-Dave
JDM_DOHC_SiR is offline
Old 08-23-2004, 05:08 AM
  #3362
Sow&Steady's Avatar
Default XRAY T1 Factory vs TRF 415
Folks,
If you're interested, MarkP has posted a comprehensive review of the XRAY T1 Factory Kit comparing it with the TRF 414 at 3hobby.com.
Click "Read more ..." when you go there and enjoy!
He plans to write part II of review as he progresses with building both these kits.
Cheers.
Sow&Steady is offline
Old 08-23-2004, 05:34 AM
  #3363
Default 415 spool
as to making a diff/spool youl need
yokomo outdrive set for mr4tc and use the front set.
diff pulley for 415 and a bering that goes inside the diff.
that is all you need for a spool.
Trfracer,
Do you use diff rings? Or do you just tighten the diff bolt down enough to lock it up?
Thanks for the input of the spool.
croy is offline
Old 08-23-2004, 06:53 AM
  #3364
s2
s2's Avatar
Default Belt stabilizer??
ive seen a 415 belt stabalizer listed, but have not seen any pictures or other info on this, has anyone got any info on it?
s2 is offline
Old 08-23-2004, 06:58 AM
  #3365
Default Re: 415 spool
Originally posted by croy
Trfracer,
only use diff rings for the diff.u dnt use them fotr the spool.
if your making a spool just tighten the bolt up as tight as possible.
if its a diff then it has to be adjusted correctly.
if your makin a spool use both the bolt and nut and glue it.
trf racer is offline
Old 08-23-2004, 07:43 AM
  #3366
TryHard's Avatar
Default Re: Re: 415 spool
Or a (probably) cheaper option is too order a ready made steel spool off of Speedtech, then all you need is another front one way pulley, if you dont want to take your one-way apart that is
http://64.70.208.72/speedtechrc/364.html
Very good quality item, it's what I'm using
Ed
TryHard is offline
Old 08-23-2004, 07:45 AM
  #3367
Default Re: Re: Re: 415 spool
Ed
true but i think the yoke outdrives are a bit lighter then steel.
Old 08-23-2004, 07:51 AM
  #3368
Does the speedtech spool work with the new
lightweight suspension?
croy is offline
Old 08-23-2004, 09:26 AM
  #3369
TryHard's Avatar
yup, the out drives are fine in length on it.
TryHard is offline
Old 08-23-2004, 01:04 PM
  #3370
Default Cady
Anyone tried the new Protoform cady yet. I havent painted it yet but it hit the shocktower in front before the tires are even close to the top of the wheelwells. Am I missing something or am i going to have to do so improvising to et it to work?
tcmerf is offline
Old 08-23-2004, 02:12 PM
  #3371
Martin Crisp's Avatar
Default protoform caddy
I tried it with rubber tires on carpet. I found it to be too loose for that application.
Martin Crisp is offline
Old 08-23-2004, 02:13 PM
  #3372
Default Re: protoform caddy
Did you have any problem getting it mounted low enough?
tcmerf is offline
Old 08-24-2004, 09:53 AM
  #3373
markp27's Avatar
Default Setup sheet
I'm a little confused as to exactly what the Front/Rear Suspension Arm Spacer are at the bottom of the setup sheet.
Are these spacers which go below the Front and Rear carbon stiffeners? If so, why is there then any need for the upper arm spacers?
Cheers, Mark.
markp27 is offline
Old 08-24-2004, 10:11 AM
  #3374
TryHard's Avatar
Not quite, I belive they are for the spacers on the inner hinge pin, for adjusting the wheelbase. At least that what i use that section for....
Ed
TryHard is offline
Old 08-24-2004, 10:24 AM
  #3375
markp27's Avatar
AH! That makes sense Thanks for the info.
markp27 is offline
