Tamiya TRF415
The Tamiya Turnbuckle Wrench(Item # 53602) is a 3mm Wrench. I thought the Tamiya Blue Turnbuckles are 4mm.....?
you right ive ordered a 3mm turnbuckle wrench which is useless to me
thanks for the car pics
Some pics of my MRE.
BTW, MuchMore servo tape is crap... cars not even been run yet since I put the speedo back in, and already it's peeling off
Knew I should have waited and got the Losi stuff as usual...
Originally Posted by Juan Aveytia
Does anyone know if any aftermarket companies make 4.5 through 6 degree caster blocks for the light weight suspension? If so, please post how to contact them.
Thanks in advance
Thanks in advance
ttt
Hope this helps.
glad to hear it works ok.
nice car ed.with those fancy blue bolts.where did you get that capacitor from?
im still waiting on bits arriving but will post pics when finished
i just needed to see how youve all fitted your electrics to work out how to go about it.and your right about that mmr tape its pants.
Hi Guy's,
I want to get some replacement belts for my MRE, but all parts stockists I know of don't have the part number belts as stated in the Rheinhard Kit. Are there other belts that work fine?
The capacitor is the one that came with the MRT MX TSX.
HiH
Ed
Originally Posted by DTM.inc
Hi Guy's,
http://www.speedtechrc.com/store/ebp...id=521&id=6301
Both in stock !!
Item # 53602(Tamiya Turnbuckle Wrench) is a 3mm Wrench.
-Info from Tower Hobbies site
Item # 49197(Tamiya Blue Turnbuckle Wrench) is the 4mm Wrench.
-Info from Tamiya America site.
If I`m wrong; tell me(prove it).
Take Care
Take Care
would any of you lot like to post some pics up of your cars so i can checkout how you all have your electrics and stuff.thanks
Super Moderator
Ok, my turn now(had to take some pics & size them properly), & later after I get a fresh body ready, I'll add a pic of that, too...
Originally Posted by JRRobiso
From what I've seen or read on this thread, some would just add alum spacers/shimms under the front susp block (.5 to 1.5mm) to increase the degree of caster or you can check these two stores: Precision RC / RC Model
Hope this helps.
Hope this helps.
i have original 415 can i put spool and direct pulley in it? what part number?
