Like Tree2Likes
Tamiya TRF415
Old 06-29-2004, 09:26 PM
  #2761
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Originally posted by =MisFitz= NuKe
Well, I didn't see any updates on here in about 5 and a half hours, boy am i on here to often. Anyways, I just wanted to let you all know I have joined the club, and cant wait to get more track time with this car.
Looks nice.... glad to have ya on board
-Dave
JDM_DOHC_SiR is offline
  #2762
Turbonium's Avatar
Trader Rating: 27 (100%+)
yea, i wasnt in that room up front that much. my friends Derek and Jay were right behind ya. i did remember that you had a few issues, prolly some due to parts availability.
Turbonium is offline
Old 06-29-2004, 09:28 PM
  #2763
Turbonium's Avatar
ill second that! congrats on the new purchase, and good luck with it!
Old 06-29-2004, 09:36 PM
  #2764
=MisFitz= NuKe's Avatar
thanks guys, dave you have already helped me a bunch with it, lol . I will be racing it at the nats and hope to do well with it in 19turn, and if I can afford it, mod.
=MisFitz= NuKe is offline
Old 06-29-2004, 10:19 PM
  #2765
Your welcome
-Dave
Old 06-30-2004, 04:14 AM
  #2766
racer's Avatar
can anyone help me out here?
if i remember correctly, someone on the forum mentioned the stock kit comes with 4 degrees of castor.
how do you get an 8 degree castor? is there an 8 degree block out there?
any help would be appreciated.
Thanks!
racer is offline
Old 06-30-2004, 04:16 AM
  #2767
racer's Avatar
JDM_DOHC_SiR,
see that your going to get your hands on the Evo IV. let us know how the testing goes
racer is offline
Old 06-30-2004, 04:35 AM
  #2768
Originally posted by racer
JDM_DOHC_SiR,
I wil 2 weeks from now I`ll be putting it together and posting out my findings with settings and such
-Dave
Old 06-30-2004, 09:18 AM
  #2769
hey Dave,
you see the thing in the one-way vs. spool thread, the note that Adrian Martinez wrote. What do you think about spools in the 415, you think I should get my hands on a spool, and try to make a solid center shaft for the nats?
Also, the money is being sent out today, hopefully I will get those parts in time for the nats. Also, can you get a solid center pulley?
Thanks,
Mike
Old 06-30-2004, 09:31 AM
  #2770
Turbonium's Avatar
mike, not sure about the spool, but tamiya is releasing a locked 1-piece center pulley. here is the info:
Item 53708 TRF415 Direct Center Pulley
not sure of the availability yet... i have modified the stock center using an extra locked pulley, as a lot of others have.
Old 06-30-2004, 09:42 AM
  #2771
Martin Crisp's Avatar
Default 8 degree caster blocks
Hi racer.
I don't know the part number, but the 8 degree was the original caster block for the TA04. They should still be avail.
Martin Crisp is offline
Old 06-30-2004, 09:53 AM
  #2772
racer's Avatar
Default Re: 8 degree caster blocks
Originally posted by Martin Crisp
Hi racer.
Thanks, for your help.
oh, and regarding your one-way setup.
would it work with a stock motor as well?
Thanks again
racer is offline
Old 06-30-2004, 10:39 AM
  #2773
Fully Hopped's Avatar
Default Titanium Screws
Hi,
Does any 1 have a list of the screw sizes and how many I would need to upgrade to TI.
Fully Hopped is offline
Old 06-30-2004, 12:47 PM
  #2774
Paul_Kultcha's Avatar
Thanks!
Someone posted a few pages back that the TA04 blocks - the 8 degree blocks - where actually the same as the stock TRF415 blocks. The difference in Castor comes in the amount built into the chassis mounted toe blocks and the spacers underneath (amount of anti-squat).
Paul_Kultcha is offline
Old 06-30-2004, 12:54 PM
  #2775
there is enough room to fit a second locked pulley? I am not seeing it, or are you modifying the second pulley to fit in the same amount of space the one way did? Also, are you grinding a flat spot on the shaft for the set-screw?
-Mike
