Old 04-17-2004, 01:50 AM   #1861
dyaz21's Avatar
JRRobiso,
Have you ran your 415 yet? I just finished my first ever pack on mine, and all I can say is WOW! This car feels planted from the get go... only thing I changed so far from the kit setting is to stiffen up the front one step with the blue springs... the kit setting is too soft up front for my driving style... (btw, this is eeyan disguised as dyaz... he needs to catch up on his posts... )
dyaz21 is offline   Reply With Quote
Old 04-17-2004, 02:08 AM   #1862
JRRobiso's Avatar
Send a message via Yahoo to JRRobiso
Talking
Originally posted by dyaz21
JRRobiso,
Eeyan?!,
Nope, making some fine adjustments to the car. I'm about 98% done (need new rear holes for my existing body that I use on my 414M). Bought new motor today (Monster of Touring) and discharge tray by Integy. My 3300 mah batteries only go up to 2600-2800 mah when I charge them. The only hop-up parts I added to the kit was the blue alum cyclinder nuts & blue spring ret. Will post some pics when I get a chance.....
TAOB Racing Team (2004) | Team Driver #101
TRF415MSX | TRF415MRE | TRF801X/XT | K V1 RRR Evo WCE | K IGT2 Audi A4 DTM | AE SC10 4X4
AKA | Airtronics M11 | Spektrum Pro | Speed Passion BL | OS Engines | Sidewinder Fuel | Ko Propo/JR HV/Savox Servos | MuchMore Racing | Xenon Racing | Speedmind | Sorex Tires | Twister Tires
JRRobiso is offline   Reply With Quote
Old 04-17-2004, 09:37 AM   #1863
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally posted by KilRuf
You think so? Are they different than the screws that were in the 414? I just remember people stripping them out and having to dremel the screw heads on the 414. I didn't take the risk.. so I'm using Ti screws on the lower deck.
I think it's because they were overtighten. I had the same problem with the EVO3 but I've now learn my lesson.
If you are only using part Ti screw, you should use them for the upper deck. Keep the steel ones in the bottom for lower CG.
jeffreylin is offline   Reply With Quote
Old 04-17-2004, 10:04 AM   #1864
NVisible's Avatar
Default green!
did some skimming in this thread and came across this pic. Any chance of getting those green parts or a kit with green instead of the blue?
NVisible is offline   Reply With Quote
Old 04-17-2004, 10:10 AM   #1865
forty6's Avatar
That is a Photoshop job. You can always have your parts re-anodized w/ a different color.
forty6 is offline   Reply With Quote
Old 04-17-2004, 10:14 AM   #1866
NVisible's Avatar
ahh. i was hoping that wasnt the case.
Old 04-17-2004, 02:02 PM   #1867
X2
X2's Avatar
Looks good in red
X2 is offline   Reply With Quote
Old 04-17-2004, 02:15 PM   #1868
NVisible a friend is midway through the reanodizing of his right now. I would look to an outside source to do the parts it is labor intensive. They parts need their original ano stripped off and then re-polished.
UF1 Seattle - SPEEDWERKES - VBC Racing - Team ORCA
Difuser is offline   Reply With Quote
Old 04-17-2004, 02:42 PM   #1869
juki's Avatar
my 415's were practically blue...:d it's got blue alumunium front body post, blue alumunium shock collar and spring retainer, blue rear alumunium knuckle ( 1 degree ), and blue wires...:d
juki is offline   Reply With Quote
Old 04-17-2004, 07:56 PM   #1870
Paul_Kultcha's Avatar
How do the Tamiya weights of oil compare to associated or losi?
Does the 600 = 60wt or ?
Also, does anyone have the Tamiya Spring Rates? For example whats the LBs on the Tamiya Blue?
Thx!!
Paul
Paul_Kultcha is offline   Reply With Quote
Old 04-17-2004, 08:58 PM   #1871
Does the new rear A mount (#53685) for the front suspension add toe out to the front hinge pins like the pro4 and XXXS? Also does anyone know where they might be in stock at?
dway100 is offline   Reply With Quote
Old 04-17-2004, 09:08 PM   #1872
Paul it is close but not exact. Look back in the pages here some one had a link to Ling's rate chart. It might be in the Evo thread
dway-yes it wil add sweep to the front arms if used with the front/front d block. As far as availibility if you are in the US, not overseas you might find it.
Old 04-17-2004, 09:36 PM   #1873
JimmyMac's Avatar
I've never really stripped the screws on my 414M2 or Evo3. I learned from reading here hehe. I just tighten them down and use thread lock to secure them. But I didn't want to take the chance with this kit. Plus Steve Wang is a great guy... so I got some Ti screws from him.. Oh... and not to mention.. I like how Ti sparks on asphalt track sometimes... hehe
Well ran the 415 today. It did pretty good. I'd still like to try a few things though on it. I ended up using my Yok SD for the main just to get some lap times on it.. and well... that was a bad mistake. It was almost a sec off pace. I gotta get that car setup right again. Gonna toss the CGM chassis and put on the RaySpeed back on. Then I can make some more accurate comparisons between the cars.
Anyways, got some more tweaking to do.
M.J. McIntyre
Yokomo YRX12
Tamiya TB03
JimmyMac is offline   Reply With Quote
Old 04-17-2004, 10:31 PM   #1874
TRF_StEvE's Avatar
hey guys, where the quickest place to get a front bulkhead ? broke mine running in the car park yesterday i'm about to check tower/speedtech. what belt tension are you guys running ?
steve
TRF_StEvE is offline   Reply With Quote
Old 04-17-2004, 11:37 PM   #1875
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
well, thought id report on my front diff deal... works as planned, no problems at all. very hooked up on our surface here, just gotta fine tune setup. now, i gotta go order the second locked pulley to finish the job.
Wes
Team Novak
Turbonium is offline   Reply With Quote
TAMIYA TRF415 Xray XB8 R/C Items: For Sale/Trade 32 04-04-2008 08:50 PM
Tamiya TRF415 Crashmaster R/C Items: For Sale/Trade 19 12-13-2006 04:48 PM
Tamiya TRF415 MS NIB koabich R/C Items: For Sale/Trade 8 11-11-2005 07:28 AM
F/S Tamiya TRF415 rraden R/C Items: For Sale/Trade 20 06-10-2005 09:02 PM
Tamiya Evo IV or TRF415 TheDevil Electric On-Road 23 10-15-2004 07:27 PM
