Houstons Engine Service H.E.S.
#3631
Honestly I enjoyed the comparison. I had a vspec and went to a n21r. It was so much easier for me to drive. I only wish for a little more bottom but not lightswitch torque like the vspec. I was running a OS 2050, I now plan on getting a 053 or 9901 pipe. I am curious to here anyones thought on a 086 pipe on a small to mid track with a n21r.
LOL now where did I questions Monty's service ? why even bother to say such things and insinuate I am ?...nothing like putting words in my mouth bro !
I butted in and offered a little tip on tuning the FMS in a Truggy.... everyone then started almost getting defensive from my posts so I attempted to clarify myself as to not be misinterpreted, nothing more, nothing less..... Honestly I regret even bothering now.....I tried to be as peaceful and respectful as possible, but some people are not interested in hearing another view if it doesn't quite match their own.. Sorry guys the bottom end on the FMS doesn't impress me much, and I am not the only one who will say that... So i see no harm in suggesting running a little higher compression to help the bottom end out a little, which is what seems to have offended so many.....talk about accidentally stirring up a angry bee's nest ! definitely not my intention at all...but some will read into things what they want to read into it !
Monty dude ! once again I apologize for butting in, I was worried crap like this would happen, and unfortunately even against my greatest efforts it has... cheers dude !
no harm intended at all !
#3632
I do like the 9853ss pipe on it better though with the short round header on smaller tracks, and even on bigger tracks you could just go up one tooth on the clutch bell and be golden...
#3633
i think you mis read once again.. i think he was referring to you and your mod work on the B5 being mentioned in a Nova thread.. not that you questioning Monty work... and least that show i read it.. but i may be wrong... Neal i Never asked for tuning advice.. i ask what pipe header combo they are using just to get a base to start from when i start to run it... and if i should re-shim to .8 for 30%.. i retune myself after that.. i am ok with tuning an engine... if i have problems i will PM Monty or call him cause this is his specialty...
And yes my typing sucks, and maybe the way i worded it also. Im sorry if you took it that way. Maybe i did also. But there is so much confusion on some of these sites!!For engine tuning!! I think that it should be left for monty to answer, as alot of these engines are tuned from him. Sorry if i started anything ,But thats just the way i feel.
#3638
first I mentioned that to help the FMS on the bottom I suggest running less shims not more...
people replied in shock that I would want more bottom end
I responded that its all relative to what your used to running...
I was asked what I run that would make me feel a FMS is soft on the bottom
I reply a mod B5 as a example..
I was then asked how the B5 and FMS compare...since my B5 is modified I must give the same benefit to the FMS so I compare the mod B5 and mod FMS...one is a torque monster, the other is a top end screamer, its that simple !
I hope this explains chronology of this thread and why I mentioned the things I mentioned...
#3643
Got a question. Ran my FMS again today with the 8mm venturi. I started it up with a slightly richened needle from last run. The engine would not clear out and would backfire at wot. I leaned high speed about two hours and engine started running great. After about half tank of fuel I richened the low speed needle about one hour and did not change the high speed needle. My engine again started sounding loaded up and backfiring. I closed the low speed needle back and again engine started running good. Would this be caused by a bad glow plug? Also, is there a rule of thumb on which glow plug to use? I'm in Alabama where the temps are 90-100 and the humidity is always 50% or more. Maybe suggestions going from day time to evening. I use 25% nitro w/ .7mm shimming. Have been using 97t or 77t odonnell plug. Thanks
#3645
Well lets dissect the conversation a little here my friend..
simply put... you mis read or mis interpret thats what caused all off this lets no forget that...my friend
22Likes
