Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 08-20-2010 | 11:34 AM
  #3781
revo61's Avatar
If you want more bottom then a 2084 or 053 pipe will be better. I have the Hotmods version and coming from a vspec the bottom is soft. But it just screams on top, and I was running a OS 2050. I have 086 coming and I may borrow a friend 053 to test.
Originally Posted by Lonestar
Monty - thanks for stepping in.
Yes my friends is as bone stock as can be. We know what makes a fantastic mill is the fit between parts, so he might have been just fantastically lucky, but still
Ok - one more vote for shimming then... I'll pull it apart and check how much it has.
I'll have a look at this closely. You do confirm the 086hs is the hot pipe for this engine, right? (which would be great as I really really like the fit and finish of this thing... I got the hard anodized version, amazing they sell the whole thing for less than $60!!!).
thanks
Paul
revo61 is offline
Old 08-20-2010 | 01:28 PM
  #3782
houston's Avatar
thanks
Paul
9886/41021 is the awesome pipe but dyn 086hs is great also
I have seen great consistancy out of those 3 ports so I am a little perplexed on your dilemma of feeling there is no power . Reduce shimming to .7mm for your 25% fuel , run a medium hot plug such as odonnell 100 or 77 and use that 086hs with 8mm and temps around 250 and it should be pretty darn good .
Keep me posted
houston is offline
Old 08-20-2010 | 07:23 PM
  #3783
houston's Avatar
Originally Posted by merdith6
I just finished breaking in and racing a toro team, one race, haven't had it that long yet, but it is shimmed at .80 for 30% nitro from the factory.
I took out the brass .20 shim, and replaced it with a .10 copper shim giving it .70 for break in and running with 25%....Seems to be pretty happy......
for best performance on the toro be sure to reshim to .70mm after approx. .75-1 full gallon and use 30% (byrons recommended) race 3000 , the extra oil will boost low end performance slightly
houston is offline
Old 08-20-2010 | 07:30 PM
  #3784
houston's Avatar
Originally Posted by KWT-NITRO
LOL
a baller because of the different car brands i run or because of the titles??
i have an H.E.S P5 and am loving it, it gave me my national title, my plus 4 is the 09 tuned one not the new team edition. i love both and not sure what to get again.
i guess i got few skills will see in Pattaya
cheers
Ali
you better make up your mind soon Ali
houston is offline
Old 08-21-2010 | 05:09 PM
  #3785
rotarynut's Avatar
Smile
Hey Monty,thanks for a great engine and excellent customer service,going the EXTRA mile for your customers.the FMS now has little more than 3/4 gal of fuel thru it, I still feel a little pinch @ TDC when cold, I'm gonna try to go the track monday to get a good feel for what it's capable... not that can't tell alreadyThanks,Robert.
rotarynut is offline
Old 08-22-2010 | 06:46 AM
  #3786
houston's Avatar
let me know how it goes
And thank you for the kind words
houston is offline
Old 08-22-2010 | 09:39 AM
  #3787
Lonestar's Avatar
Keep me posted
Thanks all
My mill indeed has 0.8mm, I took it down to 0.7mm, which happens to be what my buddy has on his as he confirmed it on the phone yesterday (thanks buddy!). I'll try this with the stock nova #6, then switch to odo100 to see what kind of change there is. Re temps, my second-hand exergen is still in the mail as the seller inadequately forgot to send it
Will keep you all posted
Thanks,
Pauk
Lonestar is offline
Old 08-22-2010 | 10:58 AM
  #3788
Can the FMS shimmed at .7mm run 30% nitro safely? I've already run almost one quart of 30% at .7mm, seemed fine with no unusual noise. Thanks
Dirtdobber is offline
Old 08-22-2010 | 06:17 PM
  #3789
Monty you know anything about this engine? Ceo Mod Crono RS8 i picked it up. In mint condition. The carb says novarossi. Bearing size?
jmoneym is offline
Old 08-23-2010 | 07:54 AM
  #3790
houston's Avatar
Yes , it won't kill the engine dobber but there is increased efficiency running .8mm shimming
houston is offline
Old 08-23-2010 | 07:59 AM
  #3791
houston's Avatar
One badass engine fershur!!!
That engine in your rig will get you a lot of "what engine is that ? That's the fastest engine I have ever seen!" Guaranteed
I know chris odonnells mods were for all out power so it might be a bit of an engine to handle
Bearing size is 14x25.4x6mm and standard 7x19x6mm front
houston is offline
Old 08-23-2010 | 08:43 AM
  #3792
Thanks i Idle and rev it for a tank today, looks like a beast, i put in max-life shoes and 1.1 springs for truggy. was going to sell it but added it to my back up list.
jmoneym is offline
Old 08-23-2010 | 02:40 PM
  #3793
cordarrow's Avatar
Well....if you decide to sell it....
cordarrow is offline
Old 08-23-2010 | 03:12 PM
  #3794
BLKNOTCH's Avatar
Hey Monty,
I reshimmed my Toro Nero this weekend from the .8 to .7, I also changed my clutch springs to 1.1 from the stock 1.0 (MBX-6 kit) and changed the header to the 41030. It was INSANE when I pulled the trigger of my M11X as I watched the buggy throw clay at every stab of the throttle, I wasn't even able to get tghe power down to make the main jump at the drivers stand LOL. I ended up putting back the 41029 manifold (short) and with a slight richening of the bottom end it was perfect mix of bottom end power and insane top end.
I love this engine!!!!!
Sean
BLKNOTCH is offline
Old 08-23-2010 | 03:30 PM
  #3795
revo61's Avatar
Anyone use the Pro Exotics PE-1 Temp Gun? What do you think of it? My old radio shack has seen better days. Looking for one in the $25-$30 range.
revo61 is offline
