Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 04-12-2009 | 07:23 PM
  #241
houston's Avatar
Tech Prophet
Originally Posted by SPEED37
Here ya go, and thank you.
thats the right one
sorry speed , i spaced it
houston is offline
Old 04-12-2009 | 07:26 PM
  #242
houston's Avatar
Tech Prophet
ron knew nitro engines
Tuning tech: carb Needle balance
We get dozens of tuning questions from around the world at Paris racing daily, The number one questions is, were do I set my needles on the carb? Unfortunately there is no such thing as a definitive universal setting for any engine!
Every application will have it's own unique requirements, even two IDENTICAL set ups can and most likely will have at least slightly different settings.
Please see tech tips following the article below [from our web site]
I would like to address what seems to be the # 1 mistake we encounter in engine tuning:
Carburetor Needle balance:
It has come to our attention some racers are making the mistake of setting the idle speed opening to wide [high idle] and setting the bottom end too rich! This will give a false normal idle speed even though the speed is set to high because it "loads up" the engine with excess fuel causing the idle to be lower than set!
The end result is a very unstable idling engine that surges and may cut out as full throttle is applied because the over rich bottom end can disguise a too lean TOP end setting!!!
Let's address this a little more in depth! Idle speed opining set too wide: It is possible too set the idle screw adjustment in to far but yet the idle speed is not high! Even though the air regulation [carb barrel or slide] may be set to a position that would normally equal a vary fast idle, the idle is low because the low speed mixture adjustment is set so rich that the engine loads up with excess fuel and the engine goes into what's commonly called a four cycle idle. One tell tail sign of this is if after reving up the completely warmed up engine it tends to idle fast for a few seconds then drops to lower idle speed.
[Here we go again with the written sound effects :-)]
Something like da..da..da..da..da..da..da..da then it drops to da da da da [if it were sheet music it would be like dropping from 8 beats per measure to 4
beats per measure]
If you start leaning the bottom end a little at a time [then repeat the reving up and idle test] and it takes longer before the idle drops your going in the right direction! Eventually as you keep leaning the bottom the idle will stay to high, now it is time to lower the idle to were it belongs by re adjusting the idle screw!
CAUTION!!!!
Now that you have the idle set correctly the top end may be too lean!!!
Keep in mind the fuel does not directly enter the cylinder area like a 4 stroke engine, it enters the crankcase area first then is transferred or pumped up to the cylinder area by the piston movement.
Simply put, the crank case volume can hold much more capacity than the cylinder so it takes some time to burn off the residual fuel.
In other words if the bottom end is to rich the engine will be supplied by this residual fuel briefly and depending on the demand you may be actually be experiencing a lean condition on the top end that can range from:
1. Seems to run well but engine life is short
2. Seems to run well but car continues to get hotter the longer you run to the point of overheat!
3. Seems to run ok on the bottom but sputters starves or strains to gain rpm
4. Seems to run ok on the bottom but when I give full throttle it cuts out or stalls
[An overly rich top end can act the same as 3 & 4 but excessive smoke and oil are usually present with a distinct blubbering sound]
There is no reason for an engine to continually get hotter unless the tune is wrong [classic #2. symptom] or there is a mechanical problem causing more load or drag on the engine as the run continues.
Exception Note: if the weather or track conditions change DRAMATICL Y. {Examples}
A light drizzle starts and the off road track goes from a very dry loose to high traction condition, or during a race a rapid weather front like a ten degree change! It is very important to fully warm up your engine, clutch and chassis before making finale adjustments.
The chassis in most applications also works like a heat sink to the engine so it is important to fully saturate the chassis!!!
I like to start the engine at least 3 or 4 minutes before our qualifier to get some heat in the engine.
[Operate the throttle by hand until you have radio frequency clearance]
It still takes at least 2 to 3 minutes of hard running on the track to fully saturate the chassis!
There is a series of restrictions to control fuel flow at different throttle/air flow positions called needles These are the five basic parts of the carb to concern yourself with:
1.The slide or barrel [regulates the amount of air to enter the engine controlled by the servo]
It simply blocks off the airflow to the engine proportional to how far it is open or closed.
2. The idle/air speed screw [sets the absolute minimum air the barrel/slide can control to maintain idle speed]
It simply is an adjustment screw that comes in contact with the side at the nearly closed/idle position.
3. The high speed needle [regulates maximum fuel flow allowed to enter engine at any throttle position]
It simply is a tapered needle that screws into the fuel flow orifice [an adjustable restriction] .
This maximum fuel flow ideally is adjusted to the correct mixture ratio for the surrounding conditions at WIDE OPEN THROTTLE or WOT
There are two more devices' the low speed or minimum spray bar and the mid range needle that restrict or control the fuel further at less than full throttle.
4. The low speed needle [regulates fuel to engine at idle]
The low speed adjustment simply restricts the flow at idle speed.
If you look down the bore of the carb you will see a long tapered needle [except for Picco torque carbs]
When the carb barrel/slide is closed the larger part or diameter portion of the long tapered needle is inserted into the spray bar, this is what's adjusted when you turn the low speed/minimum adjustment.
It literally moves either the tapered needle OR spray bar farther in or out changing the restriction independent of the barrel/side position.
This leans [more restriction] or richens [less restriction] the flow from the spray bar at idle.
NOTE: some carbs the spray bar is moved and others the needle assembly is moved, both have the same effect.
5. The mid range needle [regulates fuel to engine after idle and before full fuel position.
Notice as you open and close the carb the tapered needle [mentioned above in item 4.] enters into a small tube this is called the spray bar/jet.
This spray bar is were ALL the fuel enters the airflow stream regulated by the high speed, mid range and idle/minimum adjustments!
Normally somewhere between Y2 and % throttle open position the needle is completely out of the spray bar, This is what is called full fuel position or FFP [at this point 100% of the mixture is controlled by the high speed needle.
On many carbs the low speed and midrange are not independently adjustable so the mid rage is a factor of the needle taper and is engineered by the
factory. On some SLIDE carbs there is both independent spray bar and mid range needle adjustments. CAUTION: be very careful with these type carbs!!!
You can identify them easily because there are four adjusting screws!
0ne each for the:
High speed/top end [normally sticks up some what vertical]
Idle/air speed [normally a much smaller screw entering the carb at an angle]
Low speed/minimum [located in the end of the slide OR on the opposite end of the carb body]
Midrange [also located in the end of the slide OR on the opposite end of the carb body]
Note: if there are adjustments on both the slide and the carb body one is an adjustable mid range and the other the low speed!!! Check with the engine manufacture before attempting to adjust these types of carbs!
It is very important not to use the mid screw to adjust the low end by mistake; it is very easy to get the carb way out of sync.
Normally I recommend not attempting to adjust the mid range even if your carb is so equipped, the gains are VERY small and mostly limited to minute midrange drivability/economy changes that only the most sophisticated driver will recognize!
The negative is a carb that is so screwed up only an expert can get it back in tune!
Please note the above descriptions will apply to 99% of the modern car carbs being manufactured as of this writing with the exception of the Picco TORQUE carb that use's no mid range needle at all.
It utilizes a fuel management ramp built into the slide; the carb also has two completely independent fuel delivery spray bars/jets.
I wish I could tell every one exactly how to tune their engine but I cannot!
My hope with this article is if I can help racers to more understand How your carb works, all the other instructions and guides will make more sense!
Best Regards,
Ron
some stuff doesn't apply to our engines today but they are still excellent guidelines to follow as we all learn more about the nitro engine and how to master the art of power extrapulation . i spent a few years learning all this stuff by myself before i ever read any article buut ron is always right on the money
houston is offline
Old 04-12-2009 | 08:41 PM
  #243
Andrew_67's Avatar
What would be the better pipe for a P5X, JP 1 or a Sport Works HT, both with a curved header ?
I have the right pipe coming but in case it`s not here by this weekend i would like to run the better pipe for this engine.
Andrew_67 is offline
Old 04-12-2009 | 09:19 PM
  #244
BH
Monty, Here's a Plus4 glow plug question.
I managed to score an 08' model with the standard button.
it appears that Nova plugs aren't that easy for me to come up with. O'donnell on the other hand is.
You've mentioned both the 77 and 99. Which would you start out with and which would you run in each situation. 77 cold and 99 hot?
Thanks in advance as I've been spoiled with just having to mess with one plug for everything P3
BH is offline
Old 04-12-2009 | 09:45 PM
  #245
houston's Avatar
Tech Prophet
not one for any jp pipe myself but any pipe will work but that doesn't mean it will be the best . the sportwerks pipe with a shorter header should be a little better for ya , find a short header
houston is offline
Old 04-12-2009 | 09:51 PM
  #246
houston's Avatar
Tech Prophet
the 77 is hot , the 99 is coold . there are also the odo100 plugs which are hard to find which work excellent also .
higher humidity , colder plug
different areas like different heat ranges of plugs , try a range to find the best performance for your area
there is no magic plug or pipe or anything . just experiment based on some guidelines that you read on forums and listen to the advice of experienced nitro guys .
houston is offline
Old 04-12-2009 | 09:55 PM
  #247
BH
OK, I'll try to ask it in a way you can answer directly.
Which of the two listed O'donnell plugs are the most similar to the stock Nova 5?
BH is offline
Old 04-12-2009 | 10:05 PM
  #248
houston's Avatar
Tech Prophet
odo77
houston is offline
Old 04-12-2009 | 10:06 PM
  #249
houston's Avatar
Tech Prophet
anybody want a OSt-2060sc pipeset in pretty good shape for a good deal ? pm me if so
houston is offline
Old 04-12-2009 | 10:10 PM
  #250
bustedpiecesrc's Avatar
is that the top end pipe from OS??
bustedpiecesrc is offline
Old 04-12-2009 | 10:14 PM
  #251
houston's Avatar
Tech Prophet
do some research on it , i am not sure . i know it costs about 125$ or more from most places . it is in very good shape
houston is offline
Old 04-12-2009 | 10:16 PM
  #252
BH
Thanks Monty,
That is the OS upper end pipe. the 2050 being the lower end of the two.
BH is offline
Old 04-12-2009 | 10:21 PM
  #253
houston's Avatar
Tech Prophet
Thanks Monty,
no prob
houston is offline
Old 04-13-2009 | 08:02 AM
  #254
SPEED37's Avatar
Originally Posted by houston
thats the right one
No big deal...I found a workable solution.
SPEED37 is offline
Old 04-13-2009 | 11:31 AM
  #255
Jaz240's Avatar
Monty what's the difference between the N21 BF standard engine and the Limited edition that is $30 more? Does the Limited get longer run times?
My next engine has to go 10 minutes with no pit
Jaz240 is offline
