Like Tree2Likes
Go-Tech Engines Thread
Old 08-01-2008 | 11:53 AM
  #3991
ConciliumDesign's Avatar
Default Rear Bearing
The TKO ceramic isn't that expensive.
http://tkocompetitiondev.com/shop/pr...roducts_id=157
ConciliumDesign is offline
Old 08-01-2008 | 12:45 PM
  #3992
Originally Posted by satoch
Why has the cost of these engines been raised $90? I remember when the 7 port was $209. I got my 5 port for $187.50 shipped to my house from A-Main with a $12.50 coupon. Now the 7 port is $299! At that price I'll just spend another $25 and get an RB WS7III.
I took a chance last year on Go Tech, had good luck so I promoted the things and now I can't afford a replacement. That's crap!
Still $209 ---> http://www.amainhobbies.com/product_...ducts_id/16978
Old 08-01-2008 | 02:48 PM
  #3993
Madbrad's Avatar
I just bought a .25 Go Tech for my Revo from some one local. I want to run either a roto start or pull start, havent made up my mind just yet. I got the new era mount, but i need the correct back plate that has the shaft that connects to the crank. I cant find it any where on line, Is there a back plate I can use from another motor that would work?
Thanks!
Madbrad is offline
Old 08-01-2008 | 04:29 PM
  #3994
I think this is what you are looking for:
http://www.massivemods.com.au/produc...roducts_id=110
What country are you in? You might have to contact a GO distributor in your country.
herb99 is offline
Old 08-01-2008 | 05:51 PM
  #3995
chad24's Avatar
hey guys what is the best motor for a buggy 7 or 5 port?
chad24 is offline
Old 08-01-2008 | 05:54 PM
  #3996
Furadi's Avatar
7 IMO. It wraps out like there's no RPM limit and has tons of bottom end.
Furadi is offline
Old 08-01-2008 | 06:52 PM
  #3997
grizz1's Avatar
I agree with Furadi - the 7 port rocks in buggy. A lot of guys run the 5 ports in buggy but they are pretty savage down low. The 7 port has massive bottom end too, but it is more controllable for a buggy. The top end - well no shortage of that with the 7 port IMO go with the 7 port and 0801 pipe, you will be very happy
grizz1 is offline
Old 08-01-2008 | 09:34 PM
  #3998
I'm looking for the o ring that seals the top of the carb neck to the crankcase not the brown bottom one. Will a nova or RB o ring work I see amainhobbies has none of the GO o rings. Racefactor is hooking me up with a new carb to replace the loose one. Thanks guys.
Chedster is offline
Old 08-01-2008 | 10:23 PM
  #3999
British Menace's Avatar
Hi
I have a 5 port .21 GO with a standard head and I'm running 15% Nitro in her.
Does this motor come shimmed for 15 - 20% Nitro or 30% ?
Sorry if this Q has been asked a dozen times before.... just no time to go looking. Sorry.
British Menace
British Menace is offline
Old 08-01-2008 | 10:41 PM
  #4000
grizz1's Avatar
Originally Posted by British Menace
Hi
British Menace
They come shimmed for 30% out of the box. You will be much better off changing from the 15%. Run 25% and you will notice a big improvement in all around performance. These motors love a good dose of nitro
grizz1 is offline
Old 08-02-2008 | 05:04 AM
  #4001
Default 21 sport motor break-in
I recently picked up a go 21 sport motor for my son and I was wondering if I should breake it in like they or should I break it in like they say for the other go 21s?
jr3gone8 is offline
Old 08-03-2008 | 01:49 PM
  #4002
grizz1's Avatar
Using the same method as for the 5 and 7 ports will be fine. The break in should be a litttle easier as the sport motor won't have the same extreme metal pinch as the racing motors. Do the 12 tanks as suggested in the break in method on page 78 of this forum, but be aware the needle settings will most likely be different. Just find a nice rich setting that will give the correct temps when the head is foiled with plenty of raw fuel coming out the stinger and go from there as described in the thread. Enjoy
grizz1 is offline
Old 08-03-2008 | 06:28 PM
  #4003
Thanks, i'll try it.
jr3gone8 is offline
Old 08-03-2008 | 07:31 PM
  #4004
Madbrad's Avatar
Thanks that is part of what I am looking for.
I also need the other back plate that goes to the motor its self. It has the shaft sticking out of it where the OWB connect to it. THen the roto start back plate connects to that.
I'll check with a distributor in the US and see if they can sell me that part.
Thanks!
Madbrad is offline
Old 08-03-2008 | 07:45 PM
  #4005
mugenb46's Avatar
+1
mugenb46 is offline
