Go-Tech Engines Thread
#3991
#3992
Why has the cost of these engines been raised $90? I remember when the 7 port was $209. I got my 5 port for $187.50 shipped to my house from A-Main with a $12.50 coupon. Now the 7 port is $299! At that price I'll just spend another $25 and get an RB WS7III.
I took a chance last year on Go Tech, had good luck so I promoted the things and now I can't afford a replacement. That's crap!
#3993
I just bought a .25 Go Tech for my Revo from some one local. I want to run either a roto start or pull start, havent made up my mind just yet. I got the new era mount, but i need the correct back plate that has the shaft that connects to the crank. I cant find it any where on line, Is there a back plate I can use from another motor that would work?
Thanks!
Thanks!
#3994
I think this is what you are looking for:
http://www.massivemods.com.au/produc...roducts_id=110
What country are you in? You might have to contact a GO distributor in your country.
#3997
I agree with Furadi - the 7 port rocks in buggy. A lot of guys run the 5 ports in buggy but they are pretty savage down low. The 7 port has massive bottom end too, but it is more controllable for a buggy. The top end - well no shortage of that with the 7 port
IMO go with the 7 port and 0801 pipe, you will be very happy
#3998
I'm looking for the o ring that seals the top of the carb neck to the crankcase not the brown bottom one. Will a nova or RB o ring work I see amainhobbies has none of the GO o rings. Racefactor is hooking me up with a new carb to replace the loose one. Thanks guys.
#3999
Hi
I have a 5 port .21 GO with a standard head and I'm running 15% Nitro in her.
Does this motor come shimmed for 15 - 20% Nitro or 30% ?
Sorry if this Q has been asked a dozen times before....
just no time to go looking. Sorry.
British Menace
just no time to go looking. Sorry.British Menace
#4000
#4002
#4004
I also need the other back plate that goes to the motor its self. It has the shaft sticking out of it where the OWB connect to it. THen the roto start back plate connects to that.
I'll check with a distributor in the US and see if they can sell me that part.
Thanks!
#4005
2Likes
