Like Tree2Likes
Go-Tech Engines Thread
Old 07-30-2008 | 05:36 PM
  #3976
aznitronut's Avatar
Originally Posted by Chedster
I found that the carb is wiggling were the carb neck goes into the carb main body. I see no way to unscrew it to Jb weld it. Any ideas?
It will unscrew, I'm not sure, but it may be a left hand thread, if you have a pliers with padded jaws, just turn it with the pliers, it wil turn off, I've done with a few of the Go carbs.
aznitronut is offline
Old 07-30-2008 | 10:19 PM
  #3977
Tabushi's Avatar
Originally Posted by grizz1
Man, what a bummer. He took you right out !!!! Truggy was sounding hot too
The .25 engine + 2047 pipe its awesome, and always at 120-130 ºC ...
cya,
Tabushi is offline
Old 07-31-2008 | 06:12 AM
  #3978
aznitronut's Avatar
Have you tried the .25 with the 0801 pipe yet? I getting ready to, it seems to be more linear, from what I have heard, a friend was using the 2047 pipe with the .25, said, great bottom, top end seemed weak.
Old 07-31-2008 | 06:36 AM
  #3979
bmoneyxxxt's Avatar
I tested my 3 port r with the go 0801 pipe. I would suggest this to anyone who hasnt tried it yet, it really opened up the bottom
bmoneyxxxt is offline
Old 07-31-2008 | 09:38 AM
  #3980
will g's Avatar
finally got to run the new jammin x2 with .25 6 port/hong nor 2027 and it had tons of bottom and little top so im searching some more for the next best pipe. it was running alittle hot still like 280f other than that nothing else. i may go back to .21 for truggy but dont know if 7 port would be ok in truggy or not ? let me know what everyone thinks. i have ran the .21 5 port and ran ok but not balistic like my .25 is now. thnx will g
will g is offline
Old 07-31-2008 | 11:15 AM
  #3981
Tabushi's Avatar
.25 + 0801 its AWESOME at least in my opinion but for medium to big size tracks ... on the technical track of the video, it cuts so much bottom ... thats why i used the 2047 ...
cya,
Tabushi is offline
Old 07-31-2008 | 02:01 PM
  #3982
Hey, have any of youse guys ran the O.S. 2060 pipe-set
on any of the Go motors? If so,which motor was it and how
did it do?
rageworks is offline
Old 07-31-2008 | 03:18 PM
  #3983
mutley001's Avatar
Originally Posted by mutley001
Hi Guys,
I have a problem with my go 21 3 port sport engine, when running it makes an intermittant "rattle" sound that is definately coming from the engine not the car. I'm pretty new to nitro and have never taken an engine apart before, I've read up about it but if any of you guys might have an idea what it could be before i start work stripping it down that would be fantastic!
Cheers
Paul
Anyone?
Cheers
Paul
mutley001 is offline
Old 07-31-2008 | 09:33 PM
  #3984
Could it be your clutch making the noise? Anyone tried a OS p4 plug, my LHS is out of p3 plugs
Chedster is offline
Old 07-31-2008 | 09:39 PM
  #3985
grizz1's Avatar
Anyone?
Cheers
Paul
A rattling sound - Hmmm interesting
Couple of things -
How new is the motor
What temps is it running at
Why I ask, is that newer motors if you run them too cold when they have lots of pinch can make a "tinging" or "pinking" sound which is quite audible.
This is not a good sound as it means the con rod is getting hammered by the piston coming up on the pinch area when the engine temp is too low to allow correct "fit" between piston and sleeve. Not saying this is what's happening in your case, but it could be described as a rattle I guess. If your running below 80 deg C this might be your mystery noise. Bit of a shot in the dark, but all I can think of I'm afraid.
Let us know what you find out
grizz1 is offline
Old 07-31-2008 | 09:55 PM
  #3986
When a rear bearing is on they way out it can make a rattle sound.
When the car is running put your hand on the engine head and push down a little.
If the rattle goes away it could be your rear bearing.
herb99 is offline
Old 07-31-2008 | 09:58 PM
  #3987
MassiveMods's Avatar
Anyone?
Cheers
Paul
You may either have a loose fin on the head or it may be the tinging noise the engine makes when its tight ...
MassiveMods is offline
Old 08-01-2008 | 12:58 AM
  #3988
mutley001's Avatar
Thanks guys
I'm pretty sure its not the clutch, I took that apart and everything seems secure. The engine is not new - done about 2 gallons of fuel and usually runs at 220-240 F at race pace. I will open it up today and have a look checking the other thinks you have suggested, thanks very much.
Paul
Old 08-01-2008 | 08:09 AM
  #3989
3port sport with pull start or anything? That could be rattling on the back of the motor. Gear mesh all good? That rattles when it's loose and spinning.
T
AZTman is offline
Old 08-01-2008 | 08:30 AM
  #3990
mutley001's Avatar
No, no pull start, so its not that.
Took it apart today and can't see any thing loose in side, might be the rear bearing - I pushed down on the head when the engine was running and it did go away for a second or two then came back.
Whats the best way of making sure this is the culprit? it's not a cheap component to replace if its not whats causing the issue. Would it be catastrophic to run it until it fails?
How do I best remove it from the crank case as I can see no way to get it out? Sorry for all the questions but as I said i'm abit new to this and although its not an expensive engine I want to take care of it and learn how to service it.
Thanks for all your help so far guys, keep it coming!
Paul
