Go-Tech Engines Thread
#4726
The new washer and sealant will do the job. Just check your throttle and brake linkages and settings, particularly the linkage springs and throttle return spring if you run one. If there is too much tension on these springs it puts a lot of side strain on the carb body (especially during braking)and may be the cause of the wear on the O ring and eventually the carb movement. I prefer to run a couple of soft silicone throttle return bands instaed of a spring for this reason.
#4727
Everyone has their favourites. I find the 0801 on the 7 Port gives it wicked bottom end and it still revs out big time (but not quite as much as with the 2047, which is basically a mid to top end pipe).
I have a friend who uses the 2047 pipe with the longer header off the 0801 pipe and swears by this set up.
If you want a really smooth power band with the 7 Port and can run a two chamber pipe under your governing rules, get a Dynamite 053, you will love the results.
As far as 3 chamber pipes go, for me, I find the 0801 is very nice and gives good ecomony too.
) One more thing, i have trouble choosing between a GO .25 6 port with 0801 pipe and OS Engine .28XZ with 2060SC tuned pipe.. i'll be putting it in my CEN Matrix TR. Any input would be most appreciated.Thanks,
Jojo
#4729
Thanks grizz for the info. I would still be using the 2047 (since this is the one i have
Thanks,
Jojo
Jojo
But wait - Treat yourself to a Massive Mods Gen 5 Stage 5 modded 5 Port and you will be very impressed. Power and ecomony like you wouldn't believe. That's what I am running in my buggy and it's very wicked
#4730
Jojo
#4732
JNC it would be hard to get a accurate comparison about which engine is better in this thread, most people in here have probably never run an o.s. .28, I do not that the Go combo will leave you with more money to spend on tires and fuel for practice which will make you faster than any engine can.
#4734
Hey guys, rebuilding my Losi truggy, decided for definite sure that im going to put the Go .25 5port in it. What i want to know is, which pipe. I love the looks of the Jammin' pipes (like there is radical differences haha) but is it the BEST for performance.
Shine She may, but FLY she must!!! (usually thats the other way around but, in this case, i dont want to buy a pipe cuz i like how it looks!!)
#4735
#4737
I had an OS 28xz in my truggy and it was a pig of a thing.
I had to replace the carby straight up, it was faulty from the factory. It had a lot of slop in the rod at 1 and a half gallons (6 litres). Would not hold a tune.
In the end the crank shaft snapped at the flywheel. That was the last straw, I was not throwing any more money at it.
I know some people swear by them and dont have trouble. I dont know if I got one from a bad batch but there were a few guys having trouble at my club with the 1st batch of engines.
It has put me off OS engines for life.
MassiveMods is right about the OS rebuild costs, I think they are just too expensive and not robust enough.
Where the internals of a GO look thick and strong.
I put a .25 Go in and a 0801 pipe and love it.
Great fuel economy plenty of power to push a heavy Hyper ST Pro around the track.
I have had 2 and a half gallons (10 litres) of trouble free reliable running.
Can easily get 8 mins run time in a truggy, never tried but probably could get close to 9.5 mins with a smaller carb insert.
#4738
im running go .25 6 port i have the the go 0801 pipe and works very nice lots of bottom end still and now puts some nice top end out. i have used jp3 on it and worked pretty good but not as good as the go 0801 thnx will g
#4739
Hey guys. I've bought a second hand GoTech 7 port (Gen4 I believe) to run in my D8 for a while. I had a mate that races them take a look at it for me and he thinks that the rear bearing is just about stuffed. My question is this, if I am going to replace this bearing and make sure its running well is there anything else I should get done while I am at it?
Cheers,
Gary
Cheers,
Gary
#4740
I think of all the go engines the 5 port .21 is best for truck. It puts down good power and gets decent runtime. Although I don;t run them now I was just helping a guy on another thread and found this:
http://www.youtube.com/results?searc...rch_type=&aq=f
Go 5 port in action on a truggy
Correct me if I am wrong but is this the most current model of the go 5?
http://www.carolinasrc.com/Webstore/...idproduct=3886
2Likes
either way its good to go for now
