Go-Tech Engines Thread
#4876
I would say if you run on a high traction track you would notice a fairly big difference between the .25 and the 5 port. The .25 just explodes out of the corners, if you run on a slippery track it might not help much. They both may top out about the same.
Rex
Rex
#4879
if i ran an rc8t i would go with the .21 5port since its a lighter truggy just my 2 cents ive had both engines .25 in a truggy and a .21 5p in my buggy, sold my truggy i only run buggy now and i believe .21 5p has enough power to be awesome in a truggy i have tried both recomended pipes dynamite 053and a 086 loved both 053 to much bottom 4 me in a buggy but IMO would rock a truggy
#4881
I ran my PTM .21 5 port in my truggy for the end of last season with an 086 and the 8mm restrictor and the truggy wasnt the lightest and had tons of power all over. My question is this same mill and pipe are going into a D8 which is really over kill, what is the most economical and practical way to tone the bottum down a bit?
#4882
me personally i'd go 7 mm restrictor,1.0 clutch,and 14 tooth bell to start and see how that works for ya..also a good throttle finger will do the trick
#4883
Does anyone have a dyno specs on the go tech 3 port race, i cant find the hp and max rpm, and rpm range. Im comparing it to the sportwerks v2 .21 which puts out 34000 rpm and has 2.5 hp and the dynamite platnium .21 xp also cant find specs on this engine..pissing me off
#4884
Here you go Derek.
Maximum power: 2.79 hp
R.P.M: 33.000 rpm
Practical Range: 6.000/38.000 rpm
Bore/Stroke: 16.26mm/16.80mm
Ports: 3 + 2
Crankshaft: 14mm SG
Glow Plug Type: Turbo
Exhaust Type: Rear
http://www.massivemods.com.au/produc...products_id=72
R.P.M: 33.000 rpm
Ports: 3 + 2
Crankshaft: 14mm SG
Exhaust Type: Rear
#4886
From what I have seen and heard, they are an awesome engine at a great price.Cheers,
Gary
#4887
2Likes
