Go-Tech Engines Thread
#4714
#4715
More GoEngine Results !
Cheers to the combined MM race team !
http://www.massivemods.com.au/produc...roducts_id=147
#4716
Hello Guys,
Just wanna ask, why the 0801 pipe better than 2047? I have the GO .21 7 Port and 2047 pipe, and it does rip. I can stand against V-Spec Speed and not be left behind..... too far..
Thanks,
Jojo
Thanks,
Jojo
#4719
I think there is barely a loss in milage on the .25. When I raced last weekend it was getting the same/if not better run time than my buggy. If I recall the .25 was leaner, but yeah, about the same for run time if you tune the same. At least 8 minutes, maybe 8.5-9 at times.
#4722
I have a friend who uses the 2047 pipe with the longer header off the 0801 pipe and swears by this set up.
If you want a really smooth power band with the 7 Port and can run a two chamber pipe under your governing rules, get a Dynamite 053, you will love the results.
As far as 3 chamber pipes go, for me, I find the 0801 is very nice and gives good ecomony too.
#4723
either way its good to go for now
#4725
2Likes
, 7 to 7.5 with a jp3. As far as carb issues, solved that problem with a nova carb
