Go-Tech Engines Thread
#2491
Hi FalconXR- , best pipe I have found so far for the 5 Port turbo is the Dynamite 086 which is available from A-Main in the US if you can't find one locally. This is a top end pipe which brings out the mid / top end on the 5 port which is traditionally a little flat at the top (as compared to the 7 port).
It comes with a medium length U bend header which also makes use of the 5 ports wicked bottom end power and gives you plenty of punch down low. The 086 gives pretty smooth power right through the range. I am also experimenting at present with the LRP 2063 pipe from Massive Mods (in Aus) http://www.massivemods.com.au/index.php?cPath=1. This pipe is also very good, with huge bottom end on the 5 port and pretty smooth right through the rev range too. I am thinking it may be as good if not better than the 086 for my track and local conditions, only time will tell. A lot of guys over here are running the new Go 2047 pipe, but mainly on the 7 Ports and 3 Port R Spec motors. I tried one on my 5 port but wasn't overly impressed to be honest. As of this moment I would have to say that the 086 is king for the 5 port, IMO of course
#2492
i thought it was my clutch so i switched to the mip 3 shoe clutch that i had in my box and it does the same thing. it hesitates then it takes off. its really aggravating that it does this but ill try everything as soon as i get a gallon of fuel from the hobby shop.
#2493
22Racer - I think I should be at round 2. I just can't get the bottom of my engine correct, and stay there. It is like a razor, just one little thing changes and it goes too lean to where it lean bogs or it goes fat.
#2494
Hey zJatoRad I have the same combo - 5 Port Turbo and JP-4 pipe and am wondering if this is not an ideal combo?
The engine runs nice with solid mid range but not much down low performance which I need to clear some largish jumps. Plus a little more top end would be nice. I don't know, it just seems a little flat at the moment. Maybe I'm being to critical perhaps.
Can you expand a little on your experiences with this combo and how the performance has increased? I'm not overly concerned with run time at the moment, just general engine performance comparisons between pipes.
Cheers
Falcon
Cheers
Falcon
#2498
Hey T-Mizzle give me an update on the 25--also what pipe and plug are ya using. Waiting on Brian (PTM) to get one headed my way, gonna put on my STRR for the Border Wars series here in alabama--gonna try to give these OCM test trucks a run for there money!!!
Thanks man--you gonna try to make it to the SIC (basically the AIC under new management and different time of the year--should be cool, but without the wood jumps in ATL).
Jason
Jason
#2500
Here are the videos i edited from the last Southamerican Championship (2008 - Venezuela) ... enjoy ! :
Video 01 : CEN FRE (Pato Concha's Car) on 1/4th Finals : http://www.revver.com/video/838562/2...-fre-01-of-02/
Video 02 : CEN FRE (Pato Concha's Car) on 1/4th Finals : http://www.revver.com/video/839160/2...-fre-02-of-02/
Video 03 : Semifinals Video 01 of 02 : http://www.revver.com/video/841812/2...semifinals-01/
Video 04 : Semifinals Video 02 of 02 : http://www.revver.com/video/842289/2...semifinals-02/
Video 05 : Finals 01 of 02 : http://www.revver.com/video/847834/2...mps-finals-01/
Video 06 : Finals 02 of 02 : http://www.revver.com/video/848782/2...mps-finals-02/
cya !!
cya !!
#2502
Well i ran 4 tanks through my 5 port so far. Woulda done more, but my buddies truggy brake linkage came out got stuck and sent the truggy WOT under his car. Its all good though. Now just gotta wiat for my buggy to arrive.
#2503
Try the Jamming JP-4. It is another option. I know many ppl like it at my area with Go Tech 5/7 port.
2Likes
