Like Tree2Likes
Go-Tech Engines Thread
Old 12-26-2007 | 05:54 PM
  #991
Jason Halvorson's Avatar
Originally Posted by dgraham225
ok, well seems ive lost the used p5x i bought due to a little excess connecting rod wear, haha! so instead of rebuilding it, im gonna give the go's a try, why not? its only a little more for a brand new one than to rebuild the other!
i have a points series race Jan. 20, so i have to have the motor before then. would you think the 3 port would be available by then? im curious as to how much a difference there will be between the 3 and 5 port motors.. whether it will be worth the wait..
also, i know its hard to tell, but do you think some of the online vendors will have the 2047 pipes in stock in the next week or two? sounds like the pipe to have from what ive read! thanks guys!
the only person that can give you the correct answer to your questions is Rocket42...
Jason Halvorson is offline
Old 12-27-2007 | 08:42 AM
  #992
dgraham225's Avatar
so, how bout ya rocket42? lol! ill send him a PM and see what i can find out. thanks!
dgraham225 is offline
Old 12-27-2007 | 09:54 AM
  #993
i got my go tech .21 7 port on the way standard head, but good enough to try out the line of engines
derricklong38 is offline
Old 12-27-2007 | 10:56 AM
  #994
I think he's out of town for the holidays or something. I PM'd him a few days ago and still haven't gotten a response. Usually he's pretty quick about responding to PM's though. Just a heads up...
revo_race is offline
Old 12-27-2007 | 01:30 PM
  #995
Boadazofa's Avatar
does anyone know what is a direct replacement carby for a go 5 port?
Boadazofa is offline
Old 12-27-2007 | 01:55 PM
  #996
mugenb46's Avatar
NR,RB,OS will fit the GO
mugenb46 is offline
Old 12-27-2007 | 01:56 PM
  #997
mugenb46's Avatar
Russ, you at work man, i see you lol give me a shout asap
mugenb46 is offline
Old 12-27-2007 | 02:00 PM
  #998
Why bother? The Go carb is awesome.
satoch is offline
Old 12-27-2007 | 02:04 PM
  #999
mugenb46's Avatar
Ya what he said LOL if you have a carb leak issue or something feel free to give me a call, it's a simple fix
mugenb46 is offline
Old 12-27-2007 | 02:08 PM
  #1000
Rocket42's Avatar
Yeah sorry guys I was out of town for Christmas, but I am back now.
Voodoodaddy, thats great news thanks for giving the engines a shot.
Derricklong, congrats man the 7port rips just be patient and make sure you use the correct pipe and clutch and when its set up right it is hard to beat.
Boadazofa, Go carbs are available at amainhobbies.com, if you want to try a different brand, O.S. and Novarossi carbs will fit.
Dgraham225 it may take a little longer for the pipes to be available then what you will need to race on the 20th, remember you want to have your engine broken in before heading to a big race so you will need to burn 1-1.5 gallons till the top end breaks in. The pipes should be available by the 20th so if you have another pipe you can use for break in then it would be worth the wait. Estimated cost on the Go tech pipes should be $84.99.
We are still waiting on our test 3port race engines, but discussion with the factory have said that the engine is very similar to the 5port, so I would expect a engine with strong bottom, good mileage, and a fast spool up. If your used to a p5x I would say get the 5port and you won't be dissapointed at all.
Rocket42 is offline
Old 12-27-2007 | 03:15 PM
  #1001
dgraham225's Avatar
alright, thanks man! so ill go with the 5 port now and buy the 3 port later just for shits and giggles, haha! question tho, how does the 5 port work with the JP line of pipes? i have a jp-2 right now that i used with the p5x, but i can get ahold to a couple different ones. the track is a fairly small tight layout, around 33-36sec lap times. thanks again!
Old 12-27-2007 | 03:27 PM
  #1002
mugenb46's Avatar
With that size track, a 053 or a 2060 would be great if you can find one and the 086, dynamite makes those as well and for less, the JP pipes are are good, but you can get more runtime out of the others, and try the turbo button
mugenb46 is offline
Old 12-27-2007 | 05:07 PM
  #1003
Boadazofa's Avatar
thanks for the info guys, the reason i was asking is because i have a new go engine minus the carby.
Old 12-27-2007 | 07:59 PM
  #1004
dgraham225's Avatar
well i ordered the go 5 port turbo, and went ahead and got the 086 pipe just because carolinas has it for a really good price right now on clearance, but im still awaiting that 2047 also! i cant wait to try it out, see what everyones been talkin about!
Old 12-27-2007 | 08:32 PM
  #1005
mugenb46's Avatar
DG225, the 086 is a good pipe for the 5, the best i can describe the feel of the 2047, is like a Honda CRF 450R, hard pulling bottom but smooth, and the top end of a R6 LOL the GO pipe is killer
Boadazofa get the GO carb, you will save some money and still be able to get the GO carb insert set and still spend less compared to the other carbs.
mugenb46 is offline
