Go-Tech Engines Thread
#1143
and Go 7 port.. I am somewhat of a whore when it comes to engines LOL ! J/K .. I really like alot of different brands, and tend to favor the ones that make the most power.. though my driving sucks and I actually need a mild motor ....... there are alot of very good engines these days, and the Go engines are as good as any other IMHO.... The Go 7 port has a softer bottom thenthe 5 port, but has a broader power range and better top end.... When modded i feel the 7 port has a advantage due to its massive exhaust port...I like to open that exhaust up and widen it out even further...
#1146
as for the vspec its a great engine, but will not out due the 5port and cost $60 more and will not last nearly as long, and i really like the WS7III IMO it feels very close to the same as the 5port, but once again it cost $120 more to buy...
i have owned all of the mentioned engines, but the Picco...
#1147
im sure Maximo will chime in and disagree, but i feel the 5 or 7 port Go engine is right on par with the Picco P7R...
#1148
#1149
Hey guys, question for you. Replaced the con rod in my .21 5 port today after approx 2.5 gallons (as recommended). Engine still has great pinch but can now be turned over by hand out of the car ¨relatively¨ easily.
When I took the head off I noticed the turbo button was really black. Top of piston was pretty normal. I have run the turbo head for 6 tanks. When I removed the standard button to fit the turbo, it was perfectly normal. Engine did get a little warm during 20 min final last week when O ring in tank lid popped off seat after re-fueling stop (it was starting to lose power in last 3 mins or so). Would this cause the blackening on the button and glow plug area, or is this just a combination of new plug type, fuel etc ?
Any insights would be appreciated
PS: RETRO RC, dropped that pipe off with Jerry at the shop today.
#1150
Yeah the heat could have caused it, or it could have just been some bad fuel, Don't worry about the engine not having a lot of compression, the engine still may run fine, generally when an engine is worn out it will flame out for no reason occasionally, if that happens you may want to try a slight pinch to get you going again. If you saw temps over 300f+ keep keep an eye on the front bearing, high temps can cause them to fail.
#1155
Thanks Rocket-42. I have been running truggy today after a bit of an overhaul and the .21 5 Port is fine, grunty as ever
I think I might be running the wrong plug for the fuel I'm using or something though. I have blown 2 plugs in 6 tanks since I installed the turbo head (makes for expensive running !!). I am using 25% fuel, the same mix I have been running in all my engines for 18 months or more. Was running GS or Go #5 standard plug with no problems. Now using LRP #6 that I got with the turbo head button. Ambient temps at this time of year are 20 - 26 deg C. As I mentioned in previous post the standard head button was normal colour (it's been in there for 50 + tanks) and turbo button was black as after 5 tanks.
RETRO RC - what locally supplied plugs are you runing in your 7 Port Turbo ?
2Likes
