Like Tree2Likes
Go-Tech Engines Thread
Old 04-14-2008 | 11:27 PM
  #2341
joeling's Avatar
Hi Brian,
Originally Posted by mugenb46
what fuel and plugs are you running Joe, and be sure the head bolts are tight and carb pinch bolt and back plate, my test 3 port did the same thing, i went through everything and used a P3 during breakin and sealed the pinch bolt and back plate, the head bolts where a bit losse and i think this is what caused it, are you using the extra shim, i put mine in after that, let me know.
I'm using P3. I'll have to check to make sure the bolts are tight but that will be a few days as I'm out station at the moment. I'm using the extra shim.Thanks for the heads up.
Regards,
Joe Ling
joeling is offline
Old 04-15-2008 | 08:24 AM
  #2342
Euro Stealth's Avatar
I predict a Pro Twister Mods Go .25 6port in my future, just need to sell my OS V to my buddy now..
Brian it was a pleasure talking to you, thank you for taking the time out to discuss some stuff with me.
-Brandon
Euro Stealth is offline
Old 04-15-2008 | 09:09 AM
  #2343
Originally Posted by joeling
Hi guys,
I am a newbie to nitro & I have been running a GO 5 port for the last couple of months. Recently, I installed a turbo head button & was pretty happy with the increased power. However, I have run into a little tuning problem. After running for a while, the engine sputters & there's even a loud 'pop' from the exhaust. What could be the cause of this? I measured the head temperature & it was less than 100 deg C. On top of that, I am getting 'sticky throttle' in that the engine is slow to rev down. I know that without further details, it's not easy to figure out what is (are) the problem(s) based on this simple description. Some educated guess would be appreciated. I have just changed a new fuel tank & new tubing because I was getting the 'sticky throttle' earlier so I hope that potential area of concern is eliminated.
Regards,
Joe Ling
What causes this? I experienced this during 80%(*a rough estimate) break-in completion
razor_clawzz is offline
Old 04-15-2008 | 09:32 AM
  #2344
during break in, i guess it could be unburnt fuel burning in the exhaust. the only time i have had a pop and sputtering at the same time during normal running, i had my pressure lines and fuel lines backwards
derricklong38 is offline
Old 04-15-2008 | 09:48 AM
  #2345
tonyy's Avatar
will I got 4 tanks on my 3poet race, 4 is not alot but looks like its going to be a good motor this weekend I will be racing it!
tonyy is offline
Old 04-15-2008 | 12:14 PM
  #2346
I've experienced the same pop because of a glow plug going bad from metal contamination while breaking in an engine before. It seems the micro particles of metal the engine shed during breaking had compromised the glowplug.
After changing the glowplug, the occasional pop was gone.
kaye7877 is offline
Old 04-15-2008 | 04:24 PM
  #2347
friend2friend's Avatar
hi guys! what pipe and plugs do you recomend for the 28?
friend2friend is offline
Old 04-15-2008 | 04:56 PM
  #2348
I just got my 5 port turbo. My question is I went to put the extra shim in, and found that there is already three shims installed. What thickness shims should be for break-in and what shims should be in afterward. Thanks for any information.
clebo3 is offline
Old 04-15-2008 | 06:52 PM
  #2349
mugenb46's Avatar
Use the shim that is in the box for breakin, and remove the same shim after breakin, and after about a gallon you can run the squish anywhere from 22 to 25 thous.
Run a short style hot plug in the .28 A3 is good with a MSR 1005 or JP4 and 086 pipe
mugenb46 is offline
Old 04-15-2008 | 07:57 PM
  #2350
how would i check my clearence? squish????
Old 04-15-2008 | 08:05 PM
  #2351
MassiveMods's Avatar
you can do the old soldier in the plug hole bizzo , but i prefer to check the piston distance to liner top at TDC , then minus the thickness of the head button insert , then you have the residual distance between head button and piton without shims in .. what you would then do is add this figure to the thickness of the indended shims .. then you have a total head clearance. Best to do this with a depth gauge .. digital if poss ...
EG top of piston to liner top is 3.5 mm in the 7 port , standard head button thickness is 3 mm turbo is 3.1 mm the difference between the 2 is .2 or .1 mm that is the head clearence without any shims in ... ok you then add your shims lets say you ad a total of .4 shimming that will give you a total of .6 std head button or .5 with turbo ... hope this helps ... This is called trapped compression ratio , you would be talking between 6.8 :1 to 8 :1 typically with this set up ...
Now if you were to go into geometric compression ratios between turbo and standard then thats another ball game all together ... The difference between standard and turbo geometric compression typically in this situation is Turbo 12.5 :1 , Standard
13.7 :1 hope this helps
www.massivemods.com
MassiveMods is offline
Old 04-16-2008 | 04:46 AM
  #2352
slaytanic's Avatar
Wow! That clears it all up OL! Leave it to the pro's.
slaytanic is offline
Old 04-16-2008 | 06:56 AM
  #2353
i ordered a go tech 5 port to replace my rb that i just sold. i ordered it with a turbo button also what plugs are people running and also i have a msr1005 will that pipe work good with it?
cheesecake is offline
Old 04-16-2008 | 07:37 AM
  #2354
chad220's Avatar
after 4 tanks of break in on my 5pt im starting to get that sticky throttle other guys have been talking about, but only after about half a tank. Is this normal or am i doing something wrong? also i was wondering what carb inserts work with the GO engines?
chad220 is offline
Old 04-16-2008 | 08:26 AM
  #2355
will g's Avatar
chad220
that normally comes from a servo linkage off and causing it to bind check that first thnx will g
will g is offline
