Like Tree2Likes
Go-Tech Engines Thread
Old 04-16-2008 | 02:47 PM
  #2356
petevette's Avatar
Brian Carey, you have PM.
petevette is offline
Old 04-16-2008 | 03:23 PM
  #2357
mugenb46's Avatar
Originally Posted by cheesecake
i ordered a go tech 5 port to replace my rb that i just sold. i ordered it with a turbo button also what plugs are people running and also i have a msr1005 will that pipe work good with it?
Thanks Pete, back to ya.
Cheesecake, yes the 1005 is nice on the 5 port turbo, i havn't had a 5 port of my own in sometime, but the 7 port likes it as well, the new 5 ports with the updated cranks should really put out some top with that pipe without losing to much bottom.
mugenb46 is offline
Old 04-16-2008 | 04:13 PM
  #2358
Default where
can someone tell me where to get a 3 port r? amain dont have them or carolina rc, thanks
nazman01 is offline
Old 04-16-2008 | 04:31 PM
  #2359
mugenb46's Avatar
I can sell you a race 3 port, let me know.
mugenb46 is offline
Old 04-16-2008 | 06:06 PM
  #2360
cheesecake,
I've had good luck with O'donnel 77t , 97t and O.S. P6 turbo plugs.
Brandon Powell is offline
Old 04-16-2008 | 06:08 PM
  #2361
ProTwister's the hook-up on the Go Engines.
Old 04-16-2008 | 10:21 PM
  #2362
smracer31's Avatar
whats the factory shimming on the .21 7 port(turbo). Is it one silver and one copper? then they give you another copper one in the box?
I got my engine back from russell (after he put the proper sleeve in it)and there were 3 copper shims in the engine with a silver and copper shim in the box.
smracer31 is offline
Old 04-16-2008 | 10:22 PM
  #2363
SteveJa's Avatar
need help with sticker placement for contingency program. where and how do you place the stickers ? any links ?
thanks
SteveJa is offline
Old 04-17-2008 | 12:52 AM
  #2364
SqueegUK's Avatar
Originally Posted by mugenb46
................the new 5 ports with the updated cranks should really put out some top with that pipe without losing to much bottom.
Updated crank?? I just got one of these 5 ports. When did / is the new crank coming out and what are the advantages and differences between the old crank and new crank?
SqueegUK is offline
Old 04-17-2008 | 08:12 AM
  #2365
Tree's Avatar
thanks
Every picture I have seen of a Go Tech sponsored driver, has had the sticker on the wing, so that is where I placed mine as well.
Tree is offline
Old 04-17-2008 | 09:28 AM
  #2366
mugenb46's Avatar
i have seen them in motors in the past month, where did you geys one or do you have one without?
this crank makes a smoother feel on bottom so you have more control of the bottom end grunt makes it more linier, and gives a moere mid to top pop
mugenb46 is offline
Old 04-17-2008 | 10:06 AM
  #2367
SqueegUK's Avatar
I got mine a few weeks ago now. I got it from another bloke, but it was brand new and unrun and a £40 saving on new, so couldn't say no. I believe he had it for a couple of months prior to me getting it from him.
Must be the old crank then????
What have they done to the crank to make it different? IS it different timings or more aggresive cuts in it?
SqueegUK is offline
Old 04-17-2008 | 10:10 AM
  #2368
chad220's Avatar
bumb on the carb restrictors, wich ones fit?
chad220 is offline
Old 04-17-2008 | 03:23 PM
  #2369
Novarossi restrictors drop right in.
Old 04-17-2008 | 03:27 PM
  #2370
These restrictors fit . .
http://carolinasrc.com/Webstore/Scri...ld=description
